Old 8th July 2019, 17:40   #61
Thanked: 1,761 Times
Re: Synthetic Gear Oil
Originally Posted by Traveler View Post
For what application is this needed. Usually this is gearbox or transmission oil in GL4 grade.
75w80 will be very hard to source. Check if your manual gives the option of 75w90 or 75w85.
Originally Posted by aerohit View Post
Sharing my experience. I have used both Motul
Not sure about availability, I managed to get it offline from spare parts market.
Thank you both.
Manual was saying elf 75w80 GL4 hence the reason I was looking for it.
SideView is offline
Old 22nd July 2019, 07:37   #62
Originally Posted by IndigoXLGrandDi View Post
Is it recommended to buy the Petronas Tutela Technyx 75W85 GL4+ from 99rpm.com?
Did you go for this one?
Exactly as you even I'm not able to locate this product on their website but feel like buying it as this oil matches the specification mentioned in my car's user manual. Please suggest as to me 99rpm.com reviews are not very confidence inspiring.
Ankit82 is offline
Old 22nd July 2019, 08:57   #63
hserus's Avatar
Thanked: 9,318 Times
You can go ahead and use a 75w90 gl4 oil. Try these
https://www.amazon.in/Amsoil-75W-90-...y&sr=8-1-fkmr0
https://www.amazon.in/Liqui-Moly-Ful...y&sr=8-1-fkmr1
https://www.air90.com/collections/lu...ar-oil-1-quart
(Redline is an excellent US brand and air99 is their Indian distributor)
hserus is offline
Old 22nd July 2019, 22:39   #64
IndigoXLGrandDi's Avatar
Thanked: 598 Times
I bought this Petronas 75W85 Gear Oil and have used it in our Elite i20 Asta Diesel which has run 175 KKms+ for last 13000+ Kms.
But I didn't find any difference (Shifting Quality) between this oil and my previous 75W90 Gear Oil.
I won't be using it (Petronas Tutela 75W85) again because 1. for the reason above (no difference in Shifting Quality) and 2. the shipping cost of 99rpm.com is too high.
IndigoXLGrandDi is online now
Old 26th July 2019, 10:04   #65
Thanked: 9,250 Times
I need fully synthetic Gl5 gear oil for rear differential of 75w90 or 85w140 or 75w140 or 80w90 or 75w110 or straight 90. Any grade is amongst these are ok for my use. If anyone has any lead pls share.
Amazon has Amsoil 75w90 but its listed by a new seller with zero feedback and not amazon fulfilled and thats not comfortable. Greaves Cotton won't have stock till mid August.
Sankar is offline
Old 26th July 2019, 10:40   #66
hserus's Avatar
Among the other good brands -
Liqui Moly https://www.amazon.in/Liqui-Moly-Ful.../dp/B00TQ3S392
Motul has one too.
hserus is offline   (1) Thanks
Old 26th July 2019, 10:44   #67
sagarpadaki's Avatar
Thanked: 6,792 Times
Thank you in advance.
I would suggest you stick to Petronas if it is for your i20. That is the only fully synthetic oil in the right grade available AFAIK. i20 needs 2 litres for gear oil.
99RPM delivery would take around 7-10 days depending on from your location since large liquids cannot be shipped by air.
sagarpadaki is offline
Old 26th July 2019, 11:17   #68
Motul has one too.
Motul fully synthetic gear oil is not sold here as per their India website. Motul Motylgear 75w90 which I have in the differential now is "Technosynthese" which is Motul's identity for their semisynthetic oils. It is a good oil and is GL5.
Liquimoly gear oil is not worth it at that price, especially when Amsoil synthetic is available at lower price.
Liquimoly datasheet doesn't mention GL5 (extreme pressure) explicitly which is important in rear axle differential (and bad for use in manual transmission where GL4 or GL4+ works better). So my guess is that it is more of a manual transmission oil for integrated differentials.
Both Motylgear Semisyn and Amsoil Syn is GL5 and MIL2105 certified. Motylgear is a very good oil considering its a semisynthetic. Ideally the replacement for it should be a Amsoil Sever Duty gear oil or Motul's own synthetic range which isn't available or the Mobil1 75w90 (but without LSD additive).
Sankar is offline   (1) Thanks
Old 1st July 2020, 19:01   #69
Turrrb0's Avatar
Thanked: 660 Times
I noticed in my owner's manual that the recommended oil spec is EP 80W LL, I'm not able to find any of it online after a quick search. Is there any alternative, or will this be stocked in the local shops?
Also the manual doesn't mention GL spec.
Turrrb0 is offline
Old 28th August 2021, 15:17   #70
Has anyone ordeded from CarTrends?
I see some 75w80 mentioned there:
https://cartrends.in/products/gear-o...gn=sag_organic
SideView is offline
Old 28th August 2021, 17:05   #71
hserus's Avatar
Amazon now has several 75w80 available (Motul, Ravenol (imported), Redline)
Old 28th August 2021, 19:50   #72
Thanks.
The price difference just makes me wonder if the motul we get is fake.
Motul (1 Lite) = 600 bucks
Ravenol (1 litre) = 8000 bucks (1333% higher)
Redline (3 litre) = 15000 bucks
SideView is offline   (1) Thanks
Old 28th August 2021, 20:18   #73
hserus's Avatar
Thanks.
What you’re seeing are imported stuff that includes customs duties and courier charges from abroad.
hserus is offline   (2) Thanks
Old 27th October 2021, 21:48   #74
heysac's Avatar
Thanked: 146 Times
Do you recommend MOTUL MotylGear SAE 75W-90 Synthetic Blend GL4/GL5 for Swift Petrol? The recommended one is 75w90 GL4 but I am unable to find it in the market. It has already been 5.5 years and 20K kms since last change to Shell MGO 75w90 and I am going for a long drive in a couple of days. My skepticism is from the fact that it is more viscous compared to Shell and is also GL5 compliant.
heysac is offline
Old 27th October 2021, 22:14   #75
hserus's Avatar
As long as it provides for GL4 compliance you should be fine .. many around are GL4/GL5 dual certified. What you additionally look for in a GL5 rated gear oil is the MT-1 certification that makes it fine to use with GL4 requiring gearboxes.
What gets added is a buffering agent (deactivated or buffered sulphur phosphate) that won't react with the softer metal like bronze in gearboxes that require GL4.
https://penriteoil.com.au/knowledge-...gear-oils/1036
https://www.motul.com/us/en-US/products/motylgear-75w90
The Motul website says
Specially recommended for gearboxes hard to shift and/or noisy gearboxes.
All mechanical transmission synchronized or not synchronized gearboxes, gearbox/differential, transfer gearbox and hypoid differentials without limited slip system operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speed.
