Old 14th September 2007, 15:18   #1
Is it possible to release the hand brake from outside the car?
Hi Guys,
Is it possible to release the handbrake from outside the car.
One of my friends car was parked in front of another car. The owner of the other car release the handbrake of the car from outside (somewhere from under the car) and moved the car. Is this possible?
Stig is offline
Old 14th September 2007, 15:35   #2
Thanked: 34 Times
Maybe possible but surely the car would be in gear too?
kumar2007 is offline
Old 14th September 2007, 15:43   #3
simply_sunny001's Avatar
Thanked: 19 Times
Originally Posted by Stig View Post
Hi Guys,
u dint ask the guy who did that?
simply_sunny001 is offline
Old 14th September 2007, 15:48   #4
deepaktpatil's Avatar
Thanked: 128 Times
Yes, this is quiet possible, dont know how. Otherwise how will they tow away cars without waiting for owner to arrive.
deepaktpatil is offline
Old 14th September 2007, 15:51   #5
hrishig's Avatar
Thanked: 183 Times
My question will be
Does the hand break jams all the four wheels or just the front wheels?
If it is only front wheels then I guess it is possible.
Policewala tow away the cars parked in no parking zone even if hand break is applied.
Just my 2 cents..
hrishig is offline
Old 14th September 2007, 15:52   #6
Yeah, good question!
creatza555 is offline
Old 14th September 2007, 16:02   #7
speedmiester's Avatar
Thanked: 6,976 Times
Actually the hand brake is used on only the rear wheels. Yes it is possible to disable the hand brake from outside. But i am not sure how
speedmiester is offline
Old 14th September 2007, 16:11   #8
panky12345's Avatar
Thanked: 172 Times
nah, handbrake applies to front wheels only. Have you seen any policeman disengaging hand break first and then proceed to towing? They simply lift the car and woah!!....gone!
panky12345 is offline
Old 14th September 2007, 16:12   #9
Thanked: 59 Times
Originally Posted by hrishig View Post
My question will be
Just my 2 cents..
The handbrake usually locks the rear wheels. At least on most Indian cars which I have driven. Otherwise one can never execute 180s.
I am also curious to know how the handbrake can be disabled from outside. Since the handbrake uses cable operation; it might be possible by detaching/cutting some cable under the vehicle. Experts please enlighten us.
doomsday is offline
Old 14th September 2007, 16:20   #10
Thanked: 463 Times
First of all handbrake is applied only onthe rear wheels, no debate on that.
Secondly, since its a mechanical action using cable to apply pressure the only way to release it from outside is to cut the cable or somehow loosen it.
The car can be moved forward slowly even with gear and handbrake by pushing from behind (2-3 ppl) using rocking action, it takes time but can be moved away few meter's like that.
dadu is offline
Old 14th September 2007, 16:22   #11
Lukeskywalker's Avatar
Thanked: 1,243 Times
Had asked my mechanic about this a long while ago while I had a Sumo. He showed me the adjuster of the handbrake cable underneath the car and on loosening it completely the cable goes slack hence disabling the brake, this is what cops do whle towing.
Handbrakes lock only rear brakes and not the front ones so when your car is being towed away even if it is in gear they raise the front so the rear wheels are freewheeling.
Am no expert but hope this answers some of the questions.
Lukeskywalker is offline
Old 14th September 2007, 16:33   #12
planet_rocker's Avatar
Thanked: 426 Times
a bit offtopic:
the best way to know whether the hand brake is applied on the front wheels or rear wheels -> drive the car normally at 10-20kph in an empty stretch and while taking a small turn yank the hand brake (without applying the brakes) - you will know whether the brake is applied on the front or rear wheels - on a serious note -> please dont try this method.
the hand brake is applied on the rear wheels. if the hand brake is fully applied it will be a bit difficult to move the vehicle. IMO it is possible to loosen the cable.
planet_rocker is offline
Old 14th September 2007, 16:33   #13
Thanked: 830 Times
If a car can be driven with the hand brake still engaged, why can't it be towed?
directinjection is offline
Old 14th September 2007, 16:36   #14
Thanked: 426 Times
but then you will be straining the engine & toasting the rear brakes.? (well if one is drivng the car with the handbrakes applied)
Old 14th September 2007, 16:52   #15
gd1418's Avatar
Thanked: 729 Times
Hand break works only on the rear wheels....
My question will be
Just my 2 cents..
gd1418 is offline
