Old 16th February 2016, 10:42   #106
prithm's Avatar
Thanked: 713 Times
Re: Car Air-Conditioner Cleaning to remove bacteria & fungi
Originally Posted by freedom View Post
Kiwi DrainX.
Originally Posted by sanjeevgpc View Post
Pour in 2 caps full of Lizol and let it sit for few hours.
Thanks sanjeevgpc / freedom. Will try. I am little worried about the thickness of the plastic bottle though. A good friend of mine is recommending to go with baking soda to sanitize the bottle. But I am worried about the electric motor and the pipes.
prithm is offline
Old 16th February 2016, 12:06   #107
sanjeevgpc's Avatar
Thanked: 37 Times
Don't worry about the plastic/pipes. You cant damage them unless you use acid/harpic. Lizol is safe even if you drop it on paint and leave it on. Most probably the smell is due to stagnant water and it would have gone away with just change of water but as its not easy to remove the bottle, just use lizol and use the flush method I have suggested. Good luck.
sanjeevgpc is offline   (1) Thanks
Old 22nd February 2016, 10:30   #108
prithm's Avatar
Thanked: 713 Times
Hi Sanjeev,
Did this over the weekend .
1. Covered the nozzles with damp cloth.
2. Engine start. Wipers disengaged. Spray until empty.
BELIEVE ME. WILL NEVER FORGET THE SMELL.
3. Poured 500 mL water, 250 mL Lizol, 250 mL water.
4. Spray until empty.
5. Poured 500 mL water, 250 mL Savlon, 250 mL water.
6. Spray until empty.
7. Poured 500 mL water, 250 mL Iso Propyl Alcohol, 250 mL water.
Stink started to subside.
8. Spray until empty.
9. Poured 1 lt distilled water.
10. Spray until empty
11. Took car out in the open from underground parking and allowed it to sunbath for full day.
12. Keeping reservoir empty. Took car out yesterday, noticing mild stench in cabin after turning A/C on. But, I'm hoping this too will subside after few runs in coming summer.
Keeping my fingers crossed. Thanks guys for your suggestion. Will keep you updated.
prithm is offline
Old 22nd February 2016, 10:58   #109
sanjeevgpc's Avatar
Thanked: 37 Times
Hi Sanjeev,
Good to know. You should have left the lizol water for say 30 mins before flushing it out. You may have to do it once again considering that the water is still smelly. Do not spray the water out, Use a water hose and put it inside the can and open the tap for 30 secs.
Old 22nd February 2016, 11:17   #110
prithm's Avatar
Thanked: 713 Times
Bottle is clean Sanjeev. I checked with torch light and reservoir bottle is pristine. Looks like the tube (rubber and plastic) which leads to the nozzles is where the infestation is. The smell is beyond sewage stink, it smells very rotten or cadaver type.
Very very surprised with this experience. No one in my family knows about this, they will kill me if they knew I am tinkering with my car.
prithm is offline
Old 2nd September 2016, 12:34   #111
Thanked: 108 Times
Hi
I just noticed my car has some mold. It was parked in the basement in monsoon for a about a month. Its a small patch on the rear seat and all over the steering wheel and front seatbelts. What should i do?
EDIT: i have parked it in the sun and opened the windows to get rid of the foul smell
Elito11 is offline
Old 31st July 2018, 20:48   #112
Thanked: 72 Times
Is it true that Cooling Coil of Alto (2005) can be removed for cleaning without removing the dashboard.
This video I found on youtube.
wolf_lone is offline
Old 31st July 2018, 21:09   #113
Rshrey22's Avatar
Thanked: 725 Times
Has anyone got his Swift's/Dzire's AC serviced?
Somehow in my 6 years of ownership, not even a single service advisor told me about installing an AC cabin air filter and it didn't come factory fitted either.
Now that my car's AC is no longer blowing cold air, I took it an AC servicing shop, he told me that cooling coil was choked with dust and what not.
He said, that to get to the cooling coil, whole dashboard has to be pulled out, is this true?
Is there no other way to clean the coil?
I don't want the whole dashboard to be pulled out, if something goes wrong? Or the car squeeks or rattles afterwards? What should I do?
Rshrey22 is online now
Old 1st August 2018, 10:13   #114
Thanked: 72 Times
Dashboard will be removed to access the coil..
There is one another way but its available in Kochi & Bangalore only...
Don't know how effective it is ??
wolf_lone is offline   (2) Thanks
Old 30th July 2019, 15:32   #115
Thanked: 1,007 Times
Few months back, got the 3M AC Evaporator Cleaning & Vent Foam Cleaning done. I have captured the whole process in this video:
regards,
Pranav
pcpranav is offline   (1) Thanks
