Originally Posted by AMG Power Here is a pic from the official review: Attachment 2651064
The tilt is not seen nor mentioned in the Team Bhp’s Official Review nor in any other automotive review.
It is obviously a development after use which means that there is a weakening of some component of the suspension, most likely a shock not returning to its original position.
This is a problem that affects some vehicles after a period of use although in the case of the Thar it is a bit too soon and more pronounced.
Probably why they are replacing the suspension. And the drawing indicating 1.3 cm difference in the chassis is clearly a hoax. |
The tilt is directly from the factory.
There is a deviation in the suspension mount on the chassis Quote:
Originally Posted by 2JZ-GTE I recently took delivery of My RWD Thar.
I have read about this issue in tbhp before and I didn’t take it seriously.
A few days ago my dad casually told me that he feels that the Thar is leaning towards the right side a bit. Only then I checked my car. It does lean a bit towards the right. |
While checking in the sc for the root cause along with the tech liner from Mahindra we had found that there is a deviation in the suspension mount by 10 mm
But Mahindra design tolerance is +/- 20 mm in the overall ride height from the left to right
So they considered + tolerance on the left and negative tolerance on the right and closed the case stating its within the design tolerance and its normal. Quote:
Originally Posted by BrakeDancer The words 'initial solution' there is quite scary. Has Mahindra not been able to zero down what the exact root cause is? This gives me the impression that tomorrow they could turn around and claim that the initial diagnosis wasn't right and it's something else entirely. |
Yor are completely correct.
As an initial solution they have changed the helical springs and shock absorbers in the rear but the problem was not rectified. So they have fitted the original parts back. Quote:
Originally Posted by BrakeDancer It'd be great if other Thar owners who have been using the vehicle for a while can chime in with what the situation is on their respective vehicles. Is this solely a RWD Thar issue or is this noticeable on the 4WD Thar as well?
The information could really help out others like me who are considering the vehicle. |
People are facing this issue both in RWD and 4x4
But hope the vehicles are from some particular batch
Reason: Back-to-back posts merged. Please use multi-quote option when replying to multiple posts. Thank you!
