Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 7,759 views |
![]() | #1 | |
Senior - BHPian Join Date: May 2005 Location: Location
Thanked: 9,250 Times
| Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs This article is not about big brake kits but it is about options available retaining the OEM caliper and rotor diameter of the Jimny XL JC74 or the Jimny JB74. ----- The 3 Door Jimny JB74 (K15B) and the 5 Door Jimny JC74 (K15B) have a lot of parts in common, the chassis from the front to where the transfer case sits and then from the rear radial arm mounts till the tail end of the chassis it is identical between the 3 door and the 5 door. The difference is an additional section of about a foot in length and a new cross member in the extended part in between. Similarly the cabin from the nose till about the front seats are identical in floor layout and cabin layout except the shorter front doors and thus the placement of B pillar. The the custom fit front floor mats of the 3 door Jimny is a perfect fit in the 5 door floor edge to edge. Powertrain, transmission and wheels are all the same. They are twins sharing lot of components but front brakes are not on that list. Suzuki used a 10mm thick 290mm diameter solid front disc for the JB74 3 door version but for the JC74 5 door version they used a 17mm thick 287mm diameter ventilated disc. The brake calipers are also different between these two models with the JC74 calipers having wider gap to accommodate the thicker brake discs. The brake pads are also not interchangeable between the JB and JC calipers. There is a complaint of brake judder in the Jimny when applying brakes from higher speeds and whilst repeated braking. Many have reported this in the Indian Jimny groups and is an universally reported niggle, myself included. Brake judder is caused by 1) either brake disc warping or developing hotspots and or 2) uneven transfer of friction pad material on to the disc caused due to hot spotting at high temperatures. The text from Monster Sport website listing their JB74 upgrade brake discs is copied below. So it is understood that the OE solid discs of JB74 are also not upto scratch and Suzuki most probably upgraded the fronts to vented in the 5 door hoping to mitigate the issue. Quote:
Suzuki/Maruti Suzuki when they added more mass and length to the JB74 to make the JC74 5 door Jimny they also changed the front braking system completely. The brake calipers, the discs and the brake pads are all different and not interchangeable (except for the brake discs, but not ideal as you will learn below). The brake pads are not interchangeable between these two vehicles either, because calipers are different. The calipers are different because the discs are thicker. The brake discs are different because Suzuki consider this an upgrade over the JB74 solid brake discs expecting the ventilated brakes to run cooler increasing life and decrease fade. The origins of the 5 door Jimny XL JC74 braking system can be traced to the 3rd generation Jimny JB53 with the Renault K9K 1.5L turbo Diesel engine. The JB53 inherited the upgraded vented brakes the origins of which can be traced to the Vitara/Escudo (TD01W/early TL52W) whilst the petrol powered JB23, JB33 and JB43 continued with solid brakes. Ventilated brakes are designed to run cooler than solid discs. To take the heavier K9K Diesel power plant few critical components were beefed up in the JB53; amongst which one is the vented front brakes and the other the strengthened front axle housing. Which brake pads fit? Some vendors have already figured out the fitment and have been selling the pads in Jimny circles but they have not let out the details in public, obviously due to the fact that they wouldn't be able to sell as many pads if the information is out. The brake pad part numbers wouldn't be shared to those who had asked for it, and even paying customers receive brake pads in boxes with no part numbers on the box or the pads. So I took this as a fun challenge to figure out the fitment, for both brake pads and brake discs and thus now we have options. Brake Pads FMSI ID: D556, D807
There are too many brake pads to list and some of the known names I did not mention are Bendix, Raybestos, Wagner, Ferodo etc. Some of these specific part nos are infact "Made in India" (AC Delco and Bendix) as per the Country of Origin provided. In USofA look up '98 Chevrolet Tracker 4 door to find matching brake pads. You can search with the FMSI ID D556 which will yield manufacturer cross reference for several OEM and aftermarket pads. For my friends in Australia since this model year Suzuki Vitara/Escudo was sold there you can find brake options locally. But do your research and do your homework because none of these brake pads and actually "listed" for the Jimny 5 door aka Jimny XL aka JC74. Brembo EBC ![]() ADVICS DIXCEL Note on Brake Friction Coefficient µ and DOT Codes All street brake pads sold in the United States is required to show the brake friction coefficient as a two letter code, for example FE, FF, GG, GF etc. The first letter indicates the friction at low operating temperature 93C to 204C and the second letter indicates the friction at higher temperature 149C to 343C. The coefficient of friction (µ) codes (SAE J866) assigned to the letter is as given below. A pad with GF rating would have high initial bite when cold and reduced bite friction) when hot and a pad with GG rating would exhibit high friction when cold as well as hot. The friction code gives the user an indication on how a particular brake pad behaves but is not absolute.
The brake pad friction materials contribute to the coefficient of friction and the overall performance. Most options we have for Jimny are - 1) Non Asbestos Organic (NAO), 2) Semi-Metallic and 3) Ceramic - each having their own pros and cons. I bought Bosch BC556 brake pads which are ceramic and are not expensive. I will keep the blog updated on how these perform as we go. Couple of photos of the actual brake pad are given below. -- | |
The following 28 BHPians Thank Sankar for this useful post: | arjab, arjunsatheesh, ashking101, ashpalio, Evyas, GTO, hok kolorob, HTC, keroo1099, NomadSK, porsche_guy, pramods, RijuC, Rocketscience, rroy92, Rudra Sen, sagarpadaki, sanjayrozario, shancz, shibujp, ShivC, starter, superblover, swiftnfurious, thewhiteknight, v1p3r, vaasu, vigsom |
![]() | #2 |
| Options For Brake Discs/Rotors Which Brake Disc/Rotor? Skimming the brake rotor on a brake lathe is a process familiar to most? That is an option to get the runout corrected by shaving material off the friction face before junking the rotors, provided the rotor meets minimum thickness after this. OEM rotors are junk when new combined with the brake pads that come stock on the Jimny. The brake judder could also be a "pad" problem if a quality aftermarket brake pad is combined with a new (important) OE rotor might just fix it. OE discs are cheap and a pair cost less than a set of aftermarket brake pads! That said aftermarket brake discs could be better by build and metallurgy. Research and do your homework before purchasing any of the options below or finding alternatives based on the information available below. Because none of these are actually "listed" for the Jimny 5 door aka the Jimny XL aka JC74. Brake Discs 287mm Diameter x 17mm Thick Ventilated Center Bore 108.3mm
![]() There is a dearth of availability of the particular spec brake disc, i.e., the vented 287mm x 17mm disc for 108mm hub in the aftermarket. This is most probably due to the fact that 287mm x 17mm for 108mm hub size was only used for the 3rd generation Jimny 1.5TD from 2005 till 2018. Where as the same disc (287mm x 17mm) for the 107mm hub was used in older 3rd gen Diesel Jimnyies until 2005 and in the Vitara/Escudo/Tracker I mentioned about earlier in this article. 3-Door JB74 Solid Brake Disc for 5-Door Jimny XL JC74? I have mentioned that there are people who are using 290mm x 10mm solid discs in the Jimny 5 Door with stock brake calipers. The factory fitment for the 5 Door is 287mm x 17mm vented option and the caliper is wider to fit the 17mm brake discs. I would not combine the two, it is asking for brake failure. If you wish to pursue the 290mm x 10mm solid brake rotor some of the options are listed below and if you go down this path my suggestion is to do it properly and use the JB74 brake calipers and the brake pads to go with these JB74 calipers. If you use the 3door Jimny JB74 10mm brake discs in the 5 door Jimny XL JC74 with its stock brake caliper it would probable feel okay when the brake pads and the rotors are still new because there is enough meat on the pad and on the rotor. But it is not correct you are risking it!
Why would anyone would want to risk a total brake failure seeking out remedial measures for brake judder. Brake judder always > No brakes! If you wish to use a solid rotor club it with its correct brake calipers, both solid and vented have their pros and cons. Select what works for you but use correct caliper. The part number of Jimny JB74 brake caliper assembly including caliper carrier is 55100-78R00-999 (or 55100-78R01-999), the latter is probably an updated part. The JB74 calipers are not handed are common for both sides. Brake Discs 290mm Diameter x 10mm Thick Solid Center Bore 108.3mm
![]() If you are going this route, i.e., 290mm solids, there are a lot more options than what is listed above in both OE replacement type and upgrade types. With the information above you should be able to find a suitable option that fit your budget and needs. 107MM Hub Brake Discs for the 108mm Hub JB74/JC74? Vented Disc 287mm x 17mm
![]() Solid Disc 290mm x 10mm
![]() I included the 107mm hub rotor options in the article just because it has been done and needed that covered. I then striked out the text because it is not recommended, but I wanted to bring forth that information to you. Without machining the rotor will not fit the 4th gen. If the machining is not perfect you will have more problems than you had hoped to solve. All name brand brake discs are balanced so any additional machining could throw that off. -- |
The following 24 BHPians Thank Sankar for this useful post: | arjunsatheesh, ashpalio, Ashtoncastelino, Doc_nerd, Evyas, fiat_tarun, GTO, keroo1099, na_agrawal, NEWTON-METERS, porsche_guy, pramods, quickdraw, RijuC, ROG_AK, Rudra Sen, sagarpadaki, sanjayrozario, ShivC, starter, superblover, thewhiteknight, vigsom, wbd8779 |
![]() | #3 |
| Kingpin Preload? Kingpin Pre-load Adjustment Some folks shimmed the kingpins and increased the preload on their new 5 doors to fix brake judder. This is treating the symptom rather than cause. With increased kingpin pre-load the swivel joint gets tighter it resists movement and the steering also gets tighter. A worn out kingpin or incorrectly set low kingpin preload would result in "death wobble" without ever needing to touch the brakes. If its the kingpin you will feel that on the steering wheel even if you do not touch the brakes, with or without steering damper which the 4th gen has from factory. If it shakes only when you are on the brakes get the rotor and pads inspected. If you get the death wobble or steering shake at a particular speed (provided wheels are balanced) or after hitting a rough patch do get the kingpin preload checked and if not upto spec shim it to spec. Last edited by Sankar : 28th July 2024 at 21:11. |
The following 19 BHPians Thank Sankar for this useful post: | arjab, Doc_nerd, dr_TJ, Evyas, gauravanekar, GTO, hok kolorob, peyyala, porsche_guy, RijuC, Rocketscience, Rudra Sen, sagarpadaki, ShivC, starter, superblover, thewhiteknight, vigsom, wbd8779 |
![]() | #4 |
BHPian ![]() Join Date: Sep 2009 Location: Chennai
Thanked: 1,786 Times
| Re: Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs
So, What you are saying is that, even though these brake pads are not listed for Jimny, it is a straight fit? I just got myself the Dixcel brake pads and have to say, it is way better than OE. I also have upgraded the rotors to slotted and put in Dixcel brake fluid. Last edited by Turbanator : 30th July 2024 at 17:58. Reason: Quoted post trimmed. Please quote only relevant part while replying. |
The following 2 BHPians Thank Neil Roy for this useful post: | rroy92, Sankar |
![]() | #5 |
BHPian Join Date: May 2023 Location: Jaipur
Thanked: 82 Times
| Re: Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs Wow this info is so underated. Waiting to read more about your experience. I came across a few rotors including dixcel that you have mentioned. Rotors are reasonable but calipers choice is limited I guess and the ones available like Endless are high priced. |
The following BHPian Thanks Jimmyjimmyaaja for this useful post: | Sankar |
![]() | #6 |
Senior - BHPian ![]() | Re: Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs I wish to try out aftermarket pads and rotors during my next change. Can someone advise on what options are available locally, and if they have tried them? |
The following BHPian Thanks quickdraw for this useful post: | Sankar |
![]() | #7 | |
| Re: Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs An update on the new brake pads and the brake judder issue. The brake pads Bosch Ceramic turned out to be better than I believed them to be and for the price they are underrated. So I am still using these ceramic brake pads with the factory issued rotor and have not had the brake judder issue bother me post the pad update. The company issued stock rotors (both LH/RH) had a slight runout as measured using dial gauge (but seems within tolerance'?' if going by 3 door specs'?') when I did the pad change. So I was expecting to warranty a set of rotors eventually to fix the judder. I think maybe the ceramic pads have scrubbed the rotors that I don't get the judder now. New stock rotors unused in its sealed pouch. ![]() Quote:
![]() | #8 |
| Re: Kingpin Preload? Still using the stock kingpins which came from the factory, just to clear the air. RHS Bottom Kingpin ![]() RHS Top Kingpin ![]() LHS Bottom Kingpin ![]() LHS Top Kingpin ![]() Note: There seems to be a slight weeping of grease on the LHS caliper pin boot. Last edited by Sankar : 31st October 2024 at 10:21. |
![]() | #9 |
BHPian ![]() Join Date: Nov 2021 Location: Hyderabad
Thanked: 304 Times
| Re: Brake Options | Maruti Suzuki Jimny 5 Door | Brake Pads and Discs This is gold.. Can I go for larger rotors and pads? Asking because the higher up the mountains I go, I lose the bite, so would those help or it's the vacuum boosters job to fix that? |
