Old 12th July 2024, 15:43   #1
ais
Thanked: 636 Times
Adjusting brakes for optimal performance in rear drum brake cars
I couldn't find any thread or post on adjusting the rear drum brake shoes for optimal performance, so starting a new thread. This is important because it is a safety related aspect.
The information below will be applicable to cars with front disc and rear drum brakes.
I have a VW Polo 1L TSI MT, one of the last pieces from it's discontinuation 2 years ago. Several modifications and upgrades have been made for high performance- Bilstien B12 suspension, Whiteline rear sway bar and Wolf Stage 1 tune. The 1st upgrade made was of course EBC Yellow Stuff pads.
However, on a long highway drive, I kept feeling that the brake performance is inadequate, forcing me to plan braking well in advance and use engine braking as well.
I was contemplating switching to a larger brake caliper.
Then the car would also roll back if parked on uphill inclines with the hand brake fully engaged. Here I had to park in 1st gear as well to prevent the car from rolling back.
So on the next visit to the workshop, the mechanic adjusted the rear brake shoes to fix the handbrake issue. (Normally, this should be done from the handbrake cable). The outcome of the adjustment was that one of the shoe was touching the drum, and the other was spinning freely.
Subsequently, the braking performance leapt up. On my last visit to the workshop, I had the shoes adjusted evenly. This is roughly how the wheel rotation should be with the shoe just touching the drum-
Now the performance is optimal.
When we apply the brakes, the rear brakes engage first, then the front brakes engage. The proportioning valve distributes the brake force as explained in this YouTube video-
If there is a space between the shoes and the drum allowing the wheels to spin freely, there is a clear, perceptible and uncomfortable bias in brake force towards the front brake. On the other hand, if the rear wheels' shoes are in contact with the drums, all 4 brakes work equally, and that can be felt easily. The brake pedal feel, stopping power and control over the car is hugely enhanced.
I won't need the bigger front calipers now!
ais is offline   (13) Thanks
Old 15th July 2024, 12:18   #2
Rehaan's Avatar
Thanked: 35,732 Times
re: Adjusting brakes for optimal performance in rear drum brake cars
Please always park with the car left in 1st or reverse, regardless of if the handbrake is working perfectly or not.
The handbrake is simply not reliable or strong enough to hold a car in place on an incline with any safe level of universal repeatability.
Some related threads:
1 (Switch off / Park in first gear or neutral?)
2 (Best practice to use hand-brake while parking)
3 (What is the correct way to park on an incline?) (regarding steeringwheel rotation)
I don't know the "correct" answer, but I don't think the above is the case.
I also don't agree with his "boat" analogy in the video. Whether the rear wheels are being braked or not has very little to do with their limit of lateral traction.
In fact, it could be quite the opposite -- too much braking at the rear could cause a break in traction, leading to the ass swinging around. This is also the reason you're recommended to put 2 new tyres on the rear axle... simply because lateral traction is more important at the rear (think understeer (safer) vs oversteer (more dangerous)).
Rehaan is online now   (7) Thanks
Old 15th July 2024, 12:36   #3
Thanked: 321 Times
https://Youtu.be/tUEsxZGuMk4?si=VYQK-TDEmPTMpp7h
Yes, the rear brakes will engage first in the vehicle, this has to do with rigid body dynamics. There is a term called pitch in a rigid body. The longitudinal axis i.e. the axis passing through the center of the vehicle, also know as roll center sometimes. Easy explanation is, imagine your vehicle in half front the front and this is the axis. Now assume this was not the case, and all the 4 brakes had equal forces, and the front brakes are engaging first, then the mass of the vehicle would be transferred from the back to the front causing a pitch angle of the rigid body (the vehicle). This would mean that there is less weight at the back, which means an equal braking force for all 4 wheels would end up locking the rear wheels and causing imbalance of motion. Hence the system is designed to first engage rear drums, which are not as powerful as the front discs, and then engage front discs in order to maintain the cars stability. Hope all of this explains!
Happy Motoring!
Bsilver is offline   (3) Thanks
Old 15th July 2024, 14:48   #4
ais
Thanked: 636 Times
The sequence of brakes appication is correct- rear shoes first, then the front discs. I've seen this in a couple of YouTube videos as well. More important than YouTube or Internet verification though, is how the car feels before and after adjustments. We can feel the bias of brake force shifting to the center, rather than the front doing more work than it should.
I'm got the rear shoes adjusted in my Baleno today at Panchkula. The outcome is the same. Though I've not yet driven at speeds above 60KMPH yet, there is a marked difference in stopping power. The bias has definitely improved. The front pads are Dixel, installed 5000kms ago. They were also cleaned.
The mechanic at Panchkula Auto (a really good service center) Anil Kumar remarked that while he makes this adjustment in every car, I was the first customer who knew about this. I remarked that he is the first mechanic I've met who knew about this!
ais is offline   (4) Thanks
Old 16th July 2024, 02:05   #5
Cresterk's Avatar
Thanked: 7,269 Times
Re: Adjusting brakes for optimal performance in rear drum brake cars
Rear brake bias for weight transfer only matters in cases where we stop gradually. It is to make the car not pitch forward in mundane, every day driving.
In case of any kind of emergency stops or track driving where we jam on the brakes, 90% of the work is being done by the front. Upgrading just the rear brakes would do nothing to reduce your emergency stopping distance, because that was never limited by your rear brakes in the first place.
Cresterk is offline   (4) Thanks
Old 16th July 2024, 13:55   #6
ais
Thanked: 636 Times
The topic here isn't upgrades, but adjustment for the rear drum brakes. The brake shoes should just touch the drums to retard the wheels instead of spinning freely.
Post such an adjustment, there is a remarkable difference in the effectiveness of the brakes all around for the reason mentioned in initial post.
ais is offline   (1) Thanks
Old 16th July 2024, 22:31   #7
Cresterk's Avatar
Ah my apologies, the comment about not needing bigger front callipers anymore made me misunderstand.
Cresterk is offline   (1) Thanks
Old 17th July 2024, 11:19   #8
KkVaidya's Avatar
Thanked: 835 Times
I don’t remember where i had read this nor have i studied how it’s related but you can adjust the rear shoe clearance by reversing your car and applying handbrake (not to touch the foot brake - let the vehicle stop just by the handbrake). I do try this often and it does help a little in firming up the brakes.
KkVaidya is offline   (2) Thanks
Old 18th July 2024, 15:01   #9
ais
Thanked: 636 Times
Yes, that's how brakes auto adjust in routine. However, this is to compensate for wear in the brake shoes and pads. The starting point still needs to be correct- which is as per my initial post here.
ais is offline   (2) Thanks
Old 25th July 2024, 14:31   #10
CSA
Thanked: 201 Times
Rear Brake shoes must be adjusted from ratcheting mechanism present in rear brake system and never with adjustment screw present in hand brake cable.
Modern rear brake shoe expansion is auto adjusting by design but it only works when ratcheting mechanism is not seized because of brake dust or debris present in braking system.
Get your cars rear brake ratchet cleaned so that its not seized and never lubricate it with any oil or grease.
If ratchet is free and moving freely rear brake shoes adjust and expand automatically when you apply brakes.
It's good you got brake shoes adjusted through ratchet in rear brakes.
Adjustment screw in parking cable is there to remove slack present in parking cable only and not for adjustment of brake shoe expansion.
Uploading some pictures of Renault Duster rear brake shoes and pointed with finger where to adjust on ratcheting mechanism for other users.
I hope this helps everyone.
Adjusting brakes for optimal performance in rear drum brake cars-20240724_091855.jpg
Adjusting brakes for optimal performance in rear drum brake cars-20240724_091836.jpg
CSA is offline   (3) Thanks
Old 25th July 2024, 14:46   #11
CSA
Thanked: 201 Times
Rear brake shoes are self adjusting by design in modern cars but they only work when ratcheting mechanism is freely moving.
Here is a video present on youtube for reference.
I am not sure about your method of adjustment via reversing the car and apply handbrake but I will try it
Thanks and I hope this helps everyone.
CSA is offline
