Originally Posted by dhanushs I fail to understand.. After you switch off.. and park the vehicle for 1 hour, why do you need assist in your brakes? Can you elaborate "Functionally" in using the vehicle for all intended purposes, where you are facing a problem? |
I have a break of 1 hour from work, I drive home and park my car. I don't press the brakes after switching off the engine. After my lunch break when I press the brake pedal to start the car, the pedal is hard to press already. In less than an hour.
I have never seen this much vacuum loss in any of my cars in such a short time.
Originally Posted by arjab Brake fluid, by nature, is highly hygroscopic, (i.e. attracts moisture). Your vehicle was manufactured in 2023 September and had been standing in the dealer stockyard for quite some time. Jimny's do not have a left pull. Due to the ancient recirculating ball steering system that the Jimny comes with, the steering wheel has a good deal of "free play" on either side from the 12'o'-clock position. Actually the "actual centre point" of the Jimny steering is when the steering wheel is tilted slightly to the right! |
Got my car back from Nexa service. Alignment seems fine as off now. Will have to drive more to give proper feedback
Originally Posted by arjunsatheesh My 2013 Honda Amaze has this same issue. Honda mechanics told me that this is due to a leak in the system(no abs light has come up). Since the Amaze is a beater car, I have not fixed this issue yet.
Coming to the Jimny, it does look like there is some issue. Maybe its a leak or maybe its something else. In my Jimny(Aug 23 Alpha AT), even if I park for a few days(or weeks), the pedal does not become hard. I get at least 1-2 pumps before it goes hard(when the engine is off). |
Thats exactly what made me think of this and start this thread on the forum. We have many Jimnys in my local car group, none have this vacuum leak issue or pedal going hard issue. I tried explaining it to Nexa guys over phone but they just didnt understood my point or didn't want to understand maybe. Full vacuum loss in under an hour is just not normal.
Originally Posted by subho10 What the OP is seeing is normal behavior. It may slightly differ from car to car.
All modern cars have brake boosters that require a vacuum from the engine. Get the brake fluid changed, and brakes bleed to rule out any air pockets |
Never experienced so much brake vacuum loss in under an hour of switching off the engine in any of my cars.
Originally Posted by Neil Roy Hi , cant comment much about the brake hardness in parked conditions, but I feel that brakes are not really progressive as in other cars. I have already fitted grooved brake rotors and the bite is marginally improved.
The bigger gripe is the steering pull. It is literally driving me crazy. I have tried every trick under the sun and nothing seems to work. The steering angle sensor(SAS) may be the culprit here or the pan rod. Problem with Nexa is that they dont even have the calibration tool for resetting and recalibrating the SAS. |
Yes, brakes are not really progressive but since I am coming from a Thar, the brake pedal and brake bite feels normal to me.
Alignment seems to be sorted as off now but need to drive more to give proper feedback.
Originally Posted by gotoguru Similar issue was noted in 2016 Baleno after 2nd or 3rd service. But Nexa could not identify the cause or provide any solution. This becomes a problem, when you are climbing a slope, and the car gets stalled, the brake also gets hard immediately. Unless you are the regular driver of the car, you will not know that the pedal gets hard and you have to pull the handbrake lever. |
With engine switched off, I do get 2-3 brake presses. But that is just after switching off the engine. After say 20-30 mins, I hardly get 1 press. That is what made me suspect a Vacuum leak.
So,
The car was send to Nexa service. I have to send the car with my driver, they seemed to have fixed the alignment issue as of now. I can give my final feedback only after I drive it for few more kilometers.
And for my main problem, the brake pedal going hard after parking. Well, this issue has not been addressed.
Firstly, I tried explaining that to the Nexa service guy over phone but all I got was the brake is normal, braking is normal, The car is less driven and so it has this problem etc.
They just didn't bother to listen to the problem or my explanation.
End result, Pedal still goes hard cause of loss of vacuum. And all this vacuum vanishes in under an Hour.
This sort of charade was not expected from Maruti Suzuki.
Also, got a few freebies today. My front alloy wheels got scratches.
and a few more scratches on the paint.
I saw these scratches only after I got back my car dropped home.
Good car but pathetic service and troubleshooting capabilities
