re: Steering link oil leak in my BMW Quote:
Originally Posted by Jeep My 118i - Mar 2018, 39k miles or 63k kms done, is showing oil leak.. attaching picture for reference. There doesn't seem to be oil dripping,but a lot of misting.
This model had an optional add on of variable power steering .. the one that weighs up with speed.
Please can someone tell me how urgent this is? Don't want to be looking at steering rack replacement ![Sad Face](https://www.team-bhp.com/forum/images/smilies/sadface.png) |
Are you sure it is the power steering that is leaking oil? Hydraulic oil tends to be of a reddish colour. It also has a very distinct smell and taste.
Check the power steering hydraulic liquid reservoir. If the level is low, that might be an indication. Purely going by colour alone, it looks like you have a regular engine oil leak.
Try and see if you spot where the misting is coming from. Warm up the engine and have somebody turn the wheel left and right whilst observing the steering box. Try holding a white piece of paper down into the engine bay, see if you can catch any spray.
Leaks never go away by themselves. Steering boxes might leak on its seals over time. But those can be easily replaced. Although I am not sure a BMW dealer would do it. They might want to replace the steering box. But that is not necessary if you can get hold of the seals.
But again, first get a proper diagnosis. Without understanding what fluid is leaking from where it is just about impossible to give any sensible answer on what to repair or replace.
The good news: The big known problem with the 118 hydraulic steering is in its electronics control. This is not an electronic problem!
Good luck
Jeroen
