To answer your questions -
A) Does it harm the engine than the common TC. - That would be w.r.t a wastegated TC - No. B) Does it increases the fuel efficiency - Yes. It gives the engine higher air flow all over the operating range thus requiring less fuel to achieve the same torque. It actually directly impacts the Brake Specific Fuel Consumption or BSFC - Power produced per unit quantity of fuel, which directly effects the fuel consumption of the engine. However, the overall fuel effciency of the vehicle may depend on other parameters, but is usually improved too.
C) Does it increases the power - Yes - More air means more efficient combustion of the fuel injected and hence increases the power output. &
D) Can it be retrofitted into the cars which already have a turbocharger ? No - VNT turbochargers, being controlled by the engine ECU, are pre- programmed at the OE and then sold. To change from a WG to an VNT would need a complete ECU re-mapping and compatability to ensure efficient performance. |
