Old 10th December 2023, 17:02   #1
anjan_c2007's Avatar
Thanked: 21,068 Times
Channels on the car's rooftop to regulate rainwater!
More than five decades ago the late B J.Thomas crooned "raindrops keep falling on my head". But during these modern times, apart from our heads, we are also concerned about raindrops falling on our car rooftops.
During the present times, apart from the monsoons, it rains and pours round the year in most parts of India including the Coastal, Himalayan, trans-Himalayan and Peninsular India belts. Hence, the design of our car's rain channels/gutters be it either the drip edges or roof channels with mouldings atop the roof or any other effective design, are a very important part of car aesthetics for car buyers. These designs are not a make or break for our car choice, but matter a lot when we drive during rainy spells.
It is necessary to prevent water dripping or flowing off the roofs in an uncontrolled manner for reasons like: to prevent it drenching car occupants and also prevent uncontrolled ingress into unwarranted territories like the front and rear windscreens or the window glasses.
A roof drip edge is a type of metal channel designed to regulate water from atop the car's roof effectively. It is designed from the edge of the roof, beneath the roofing and overhangs the sides of the roof. The drip edge runs along a car's windows and ends on the base of the roof alongside the A pillar and maybe C or D pillars, depending on the car's design. The bent channel like design allows the drip edge to keep water flowing away from the roof. These were universal in almost all the older cars. As the roofs were mostly convex or bulbous at the top, these were the most effective and time tested design. Aerodynamics and rising importance of the "cd" factor have eliminated these drip edges from car designs. A new Ferrari with such old type drip edges will sulk with wind resistance. Hence, for such reasons it's only with the newer flat rooftops that carmakers commenced experimenting with newer, sometimes effective or sometimes flawed designs of roof channels.
The roof drip edge design on a Landmaster carried over to Ambassadors. It was common in our Standard Heralds and older models and also the Fiat 1100 variants and successors.
Most of the newer cars with flat roofs have two channels atop the roof on either sides which are limited in dimension to only the rooftop. There is one/are two plastic mouldings alongside each channel. The rainwater is left at its mercy to drip from the front and rear windscreens, as the channel doesn't continue alongside the A and C or D pillars till the base. Hence, during heavy rains the wipers have to do their duties. And if the front window is open, with the wiper swiped to the right, rainwater often enters into the driver's cabin, as Maruti 800 drivers could have observed and sensed.
Rooftop of a Maruti 800
And another flawed design is of the Scorpio rooftop of its first three generations with the old bodyshell. The "God knows why" front sloping design, almost atop the B pillar on the roof is a major flaw. The roof height for the driver's cabin is lesser, while the height faces a one time increase from its B to C and D pillars. Mahindra could have presumed that the rear seat passengers would be six plus footers as compared to the shorter ones up in the front seats. But then, their legroom is limited or even constrained on the backseat. Back to the topic, only the two grooves atop the roof are meant to regulate rain water. Hence, rainwater gets a "free for all" and the irrational, towards front, slope facilitates it to egress, flowing through the windscreen, sometimes like a small river during very heavy showers. Hence, the wipers must be perfect for Scorpios for safe driving.
The Scorpio roof top- Mahindra's ingenuity which affects drivers the most.
The Tata Nano failed to sell, but is a perfect city runabout car. Its ergonomics is quite practical for its driver. The single wiper on its windscreen helps a lot to combat the rainwater menace. The rooftop design is quite pragmatic, with its bulging channels atop, plus the two Maruti 800 like channels sans the plastic mouldings ( Rs 1 lakh car, so cost cutting) alongside the roof.
Tata Nano, among the most pragmatic of all newer designs.
We would like to hear from fellow members about such designs on their car rooftops, for regulating rainwater.
anjan_c2007 is offline   (12) Thanks
Old 13th December 2023, 14:52   #2
Thanked: 1,767 Times
Re: Channels on the car's rooftop to regulate rainwater!
The latest car to have a rain channel is the Scorpio Classic.
The channel is above the window and not the roof
The roof grooves are to add rigidity to the roof
1.2TSI7DSG is offline   (2) Thanks
Old 13th December 2023, 15:55   #3
DicKy's Avatar
Thanked: 12,343 Times
True. Especially when braking or slowing down, the windshield will have a waterfall effect. The old TATA Sumo too had this problem if i remember correctly.
Add the Maruti Eeco, Force Gurkha, Mahindra Thar(?) and Maruti Jimny to the list.
DicKy is offline   (1) Thanks
Old 13th December 2023, 19:13   #4
Yes right you are - these have been with the design since Day One. But the roof slope from the centre towards windscreen is a great facilitator for the rain water's, rivulet like flow. As a result, the wipers need to be in a fit condition with the rubber on the blades in perfect condition.
The channel around the Scorpio's windows - a certain old world charm here:-
Old 16th December 2023, 08:04   #5
Thanked: 3,276 Times
The worst car I have owned in this respect was the Polo. During rains opening the rear door ensured that water would invariably call into the floor of the car as the slight groove did nothing to channel rain into the gutters by the side of front and rear windshields. It did not have roof mouldings.
Drive on,
Shibu
shibujp is offline
