Old 16th September 2024, 23:30   #46
Thanked: 155 Times
Re: Air Suspension Explained | All you need to know
Relevant portion of the S90 Brochure mentioning Suspension and Tyre details
adasisthefuture is offline
Old 17th September 2024, 01:01   #47
Thanked: 155 Times
However, assume you add a spacer to your strut, then it may level itself and compress down.
Thank you for your response. I do not know the technicalities of suspensions but I think the size I am upgrading to is a Volvo approved wheel size
and I do not think an OEM approved wheel size would need addition of a spacer. Kindly correct me if I am wrong. Thank you.
Old 17th September 2024, 07:26   #48
dhanushs's Avatar
Thanked: 11,463 Times
Never ever use spacers on air suspension as you will throw off the system completely! The system will adjust downwards automatically.
Jeroen
I'm not advocating the use of spacers here. Since the question was on GC and that the suspension was designed to maintained the GC. The GC change - due to change in tyre and due to a change in suspension geometry/BIW are both different, and the car would react differently for both. See my comment below. Which implies you are safe to change the tyre to a bigger size one.
.. the only constant reference point for ride height would be the car itself (eg: frame). Having ground as a reference point for adjusting ride height would be highly unreliable and improbable coming from an OEM.
dhanushs is offline
