Part 3
5. Start/Stop button LED backlight heartbeat
Purely cosmetic, but looks cool. Makes the Start/Stop button backlight pulsute, when engine is not running
Steps - - Start VCDS, after connecting to car (with ignition on) & laptop
- Click on Select button under Control Modules
- Click on 05 Acc/Start Auth..
- Click on 10 Adaptations
- In the channels drop down, select ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt
- Change the value from not active to active and click Do It
- In the channels drop down, select ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt
6. Display refuel quantity in the instrument cluster
- Click on 17 Instruments
- Click on 07 Coding
- Click on Long Coding Helper and confirm the messages shown in the pop-ups
- Browse to Byte 10
- Click the checkbox next to Bit 4 - Volume to be replensihed, Yes
- Close the long coding helper popup
- Click Do It
Correction for
2. Disable 80 kmph & 120 kmph beeps posted earlier. There is no need to change the value for
IDE14220-MAS00111-Vehicle speed warning for India-Seconds from 120 to 250 or 0 or anything else. This just specifies the number of seconds between warning beeps, when driving over 80 kmph. Just changing the value of
IDE14220-Vehicle speed warning for India to
NO is enough. Have checked and the 80 kmph warning is definitely silenced. However, could not check the 120 kmph warning, but I see no logical reason for that to go off, unless there is an individual setting for the 120 kmph warning.
Planning to do the following -
Sports Display - mainly for seeing boost pressure
Offroad display - mainly for checking altitude
ACC controls on infotainment screen
RPM bar display in the instrument cluster in virtual cockpit mode
Improved AC performance
Acoustic confirmation on lock/ unlock
Torque vectoring with strong XDS
Enhanced throttle response with dynamic mode
Improved steering feel with dynamic mode
Wiper tear drop wiping
Switch on DRL only when control swich in AUTO position
Enable rear DRL
Rear lights ON with Boot open
Enable car lock/unlock using remote with engine/ignition ON
Enable Beats sound signature for infotainment
All of the above have been done by others, so they can surely be done. Just a matter of figuring out the Adaptations & Long Coding changes. Hoping to uncover some other easter eggs along the way. Will continue to post steps for each one of the functionalities I successfully enable here.
