Re: What Next for my Altroz iTurbo? Quote:
Originally Posted by Asish_VK Your car looks to have most of the things done already and looks great. I don't have much suggestions here, but if you don't mind can you share the performance gains by the mods carried out ?
(With the remap, fuel mapping & air intake etc) ? |
Sure, the short answer is the same as what my tuner gave me - 16-18% gains on peak figures from them stage 1+ remap. So that comes to like 125 bhp and 165Nm torque.
The long answer is... There are gains but not so much in the peak bhp or torque department. More in the torque curve. You can feel the turbo spool sooner. The torque in the low end (which was already quite good) has gone up tremendously. The tune I opted for might not be for "comfort" oriented drivers because if you are not gentle with the pedal - you can feel the boost building up. Even under 2k, you can feel the engine trying to tug it's way though! And much like a diesel you can feel the sharp push of torque from 2.5k right up to 4.5k rpm (I think this is where it makes its peak numbers). That, and the last final (jerky yet fun) nudge in performance after 4.8k rpm still remains!!
About the fuel calibration - it comes at a cost. I cannot run normal rated fuel ( I only have to run 95+ rated fuels ). But I'd say it's worth it. These small turbo engines are notorious for engine knock and to manage this they have extremely harsh punishments on ignition timing to help avoid knock.
So having the 95 RON calibration, I can stay a few degrees of timing in advance (because of the VVT). This renders in less "oh what? Where's the power?" Moments and also greatened fuel economy figures!
They also offer a hybrid fuel map- where you can run normal fuel under 2k rpm and then 95/97/100 octane calibration past 2k.
This is good enough to cruise around ar 80 when tug through traffic when there's no higher grade fuel pumps nearby. But yolo, I have never been in a situation where I couldn't find a pump. And even if I did - I have a few bottles of ProOctane octane booster in my trunk aid in those situations.
The air filter is trouble honestly. It doesn't filter dust particles as well as the stock paper filter. And the placement of it (the way I have it is wrong) but pulls it hot air (almost all the time). But the crazy induction sounds you get from it gives me butterflies!
The whoosh as boost is building up and the sharp pfffft when the BOV releases the air pressure is just heart-soothing in a way!
But the dust in the intake manifold because of this and the fact that it's oiled, causes some issues. I tend to find some oily coating on my MAP sensor which needs to be cleaned or the car doesn't run properly sometimes. (Might also have to do something with the initial issues I had with her.. there are a few iTurbos that have some underlying powertrain trouble that Tata isn't able to solve).
If you have any further questions, I'm happy to help! I understand how tough it is to find and support a car that sadly has absolutely no presence in the aftermarket scene..
Hope this helps  |
