Originally Posted by torquehead Owing to DCT/DSG woes, I am considering diesel options of Creta, Seltos & XUV700(tried others as well, but couldn't consider them for reasons not relevant to this thread).
Here is my dilemma:
- I am a sedate driver who likes to enjoy the low and mid-range torque and hence stay on the lower side of RPMs(this does not imply lugging).
- There could be several days when the car is not used at all.
- There could be occasional months, when there is little city-running(200 kms) but no highway-runs at all.
Here are some of my concerns:
- If the driving-pattern above should be a cause of concern for DPF health. |
I can share my experience with DPF equipped vehicles after having owned the very first BS6 diesel vehicle in the country, that's the Seltos. I owned it for 3 years and 30k kms. I had researched on the subject quite well before taking the plunge to buy a BS6 diesel. I had made out that my driving and usage pattern won't give any DPF tantrums as such. The car was largely used on highways but there were times it logged 250-300 kms a month in the city without seeing an highway in the same period. In such instances, it was inevitable to face DPF chokes.
IIRC, I had DPF clogging issues twice or thrice. When I say clogging, I mean it called for a highway run to trigger the passive regeneration. And with prolonged city usage I was expecting to get into such a situation. So an Italian tune up ensued and all was well.
The only time I ended up with an active regeneration was during one of the scheduled services. Since I had a long journey lined up two days later, and the car was used a bit in the city limits, I requested the technician to run the diagnostics to see the soot level. It was on the brink of getting into a situation of it demanding a highway drive. Since I didn't want such an error at the start of a long journey, I proactively asked them to do the active regen. They initiated that and it was all done in 20 mins or so.
In short, expect DPF clogging if you use your cars in city traffic for extended periods. It's more about the number of hours one clocks in city than the kms. If it's crawling traffic day in day out, it's just a matter of time before DPF acts up. But if you are in a city but still can drive at 30-40 kmph for larger part of your commute, you can quite easily keep the DPF tantrums at bay. All you need to do is to drive in lower gears every now and then. Keep it on the boil a bit.
For instance, If a 30 kmph can be done without lugging the engine in gear 3, do the same in gear 2 - not every single time but more often. If you follow this religiously, DPF at least in 1.5 litre engines isn't a problem at all. By the way, I had the diesel AT Seltos. Hence I used to move it to manual mode and shift gears manually every now and then during city runs. Even on highway runs i use manual mode extensively for engine braking. But if it's bigger CC diesels like Crysta, Fortuner et al this practice can get counter productive as shared by
audioholic in his post above. Do read that.
One of the cars in my current garage is the new Thar D AT. It's a BS6 engine too, the 2.2 litre m Hawk. I largely follow the same practices shared above, with Thar too. I've done 30k kms in one year and faced DPF clogging(means it called for a highway run for passive regen) only twice. Both times, it was expected owing to extended city usage prior to that.
Once, I even pushed the city usage further by driving normally, without any conscious effort of keeping higher rpm s in lower gears, just to see how many kms can I clock in the city without any highway run. And it lasted 220 kms or so. But then, Thar is tuned for performance and it stays in higher rpm s even when you're driving at 30-40 kmph too. So all the dynamics can vary depending on the vehicle's engine and tuning characteristics.
One can buy a diesel BS6 without worrying about DPF, if they know what they're getting into. It's not much of a hassle, in my experience. Good luck on your purchase.
I'm also attaching my older posts on this subject, if it helps in your decision-making.
Originally Posted by Bibendum90949 There is just another observation. I don't have any technical details to provide. In the same stretch of roads in city limits at similar traffic and driving conditions, the car returns different FE at different times, that is at least 15-20% less. This I suspect happens when the system is trying for a passive regeneration and hence more fuel is fed into engine and owing to weak RPMs, it gets aborted.
Another thread in which DPF issues were discussed https://www.team-bhp.com/forum/techn...te-filter.html (FAQs about DPF (Diesel Particulate Filter)) |
https://www.team-bhp.com/forum/offic...ml#post4771540 (Kia Seltos : Official Review) https://www.team-bhp.com/forum/techn...ml#post4890468 (BS6 Diesel Car owners - Your experience with DPF / SCR / AdBlue here)
