Re: Maruti-Suzuki Jimny | Post purchase issues and niggles I was reading somewhere about outside smells entering the Jimny from time to time. Has anyone else experienced this, and know what the solution is?
From time to time I get the smell from outside entering my car, even through the windows are up, and the AC is set to the internal air only setting.
At the service center they checked the filter as well as that the panel was closed, but didn’t do anything else.
I somewhere read that this is a common issue, and the persons solution was to purchase a car air purifier. I feel this should be fixed by Suzuki really, and should be some kind of minor issue if one knew what it was.
Was also wondering, if when going over really bad roads (potholes) or speed brakers at a slight angle (at about 50kph), if the car sometimes slides or turns a little? My tyre pressure is 24, and otherwise the car drives ok at high speeds (100) |
