My versions in bold
Originally Posted by narayan i think gas filled shocks may not be same as air suspension bcos even bikes like pulsar and enfied have those.. Here the springs continue to exists, only the damper charge is Nitrogen or any other inert Gas instead of oil.
i think air suspension refers to an air balloon/membrane on which the body floats . this holds air and the air itself acts as the spring unline a gas filled shocks where the gas provides the damping alone... Here the spring is replaced by air bellows, which act as both the spring and the damper |
Originally Posted by fiery enzyme I don't know about enfield but the so called gas gilled shock absorbers in pulsar is a scam. I had a pulsar without it and currently own one with it and I feel the older one is better  .
Bala |
I would like to offer a small clarification here:
A typical suspension setup consists of two key components.
One is the
Spring (Leaf/Coil in the Normal sense), which effectively takes the entire load( sprung mass of the vehicle).
In rough patches, the flex of the spring will provide a better ride than a rigid direct connection, by absorbing the shocks (by effecting changes in the potential energy of the spring)
Second compoent is the
Damper, whose function is to control(dampen) the oscillations which would result, in this Energy conversion at the spring.(Before i get too technical, let me also say that, the main function of the damper is to act as an energy dissipator)
In an Air-matic suspension(MB) both the spring and damper has been taken care of , by variable air bellows.The main advantage here is that we have infinite no: of spring ratios that too electronically controlled , so more pliant ride (analogous to CVT Vs Normal gearshift)
And hence the cost factor is prohibitive. And more over the air bellows are akin to the one you can notice in many a musical instruments(although much more robust polymer rubbers), Steel coil springs have, on any given day more life and resilience and hence reliability
In a nitrox( or whatever as in those bikes) , The difference lies in the damper alone and the springs are not done away with.Only the damping fluid here is Nitrogen or some inert gas instead of our normal oil.
Hope this clears the confusion.Sorry if it was too technical
, I simply couldn't help it.
