Re: Finding my Tata Punch underpowered | Can I add a turbocharger to it? Quote:
Originally Posted by bhphog OP, I'll suggest prior to the a turbo install to try out the following, one step a time till you are satisfied:
1. Invest in a air filter, preferably BMC or K&N.
2. Contact Wolf Motorsports or any reputable tuner for a remap. With an air filter you can try a stage 1, which could improve the low end and improve throttle response.
3. Go for a cat back exhaust.
4. Go for a stage 2 map. Since you will now have the hardware, things should look good.
5. Finally, you can always reach out to Engineering Exponent, BLR or a reputable garage with proven RnD skills to install a turbo. Since the turbo, and 90% of supporting components would be OEM, I don't think it will be too difficult.
Finally and Finally if you are still not satisfied, go for an upgrade.
P.S - I would like to point out being car enthusiasts with endless knowledge of the know how of cars, how as a community and including, but not limited to, some of its senior members are so skeptical to mod cars specially on the performance end. (Not talking about plug and play mods)
The tuning and mod scene in India has upped its game drastically and cities like Delhi, Bangalore, Coimbatore and Mumbai have plenty of competent garages with proven results and cars which have run lakhs of kms even after being modded heavily on the performance end.
I really wish for this opinion to change specially since new cars are way overpriced and too disconnected from providing a good driving experience. |
There is a thin line between being 'enthusiastic' and being 'rational'.
- The OP atleast from what I have read doesn't seem to be very interested in 'how' to install a turbo in his Punch. He's frustrated with the lack of power and wants a direct solution to it. He feels a turbo will do the job for him and is looking at this from a feasibility point of view by asking us
- More importantly, no one has attempted to install a turbo on this engine in the past. Your philosophical narrative portrays it to be a simple bolt on job but it isn't. Else everyone would have resorted to strapping on a turbo to their engine
- First, the internals of the engine need to be brought into the picture. The biggest question is whether these can take all that boost from the turbo. And going through the official review of the Tata Nexon I think I have the answer already: Quote:
The Nexon petrol gets a new 1,198cc, 3-cylinder turbocharged engine from the Revotron family. It is built at Tata’s Sanand (Gujarat) plant. A 1.2L turbo-petrol might sound familiar, but this is not the same engine as seen on the Zest. The Nexon gets a heavily reworked motor based on the Tigor's naturally-aspirated unit, with the internals beefed up to handle the turbo |
Mind you, I haven't even come to the bit where a suitable turbo needs to be chosen and look at how much time and effort would be needed. This engine at least from what I can see does not have the internals suitable for bolting on a turbo. This essentially means the engine will have to be rebuilt using suitable components before one can even think of doing something like this.
Let's assume the internals are the same, a suitable turbo will have to be chosen, changes will have to be made to the intake and exhaust plumbing, oil feed and drain pipes will have to be routed. The turbo itself will have to be mounted at a suitable location.
And it doesn't end there. Assuming you have the hardware side of things sorted, you will have to use a piggyback ECU since the 1.2 NA ECM obviously won't have provisions for supporting a turbo. You will have to spend hours sitting with your tuner, doing test runs and logging data.
All this is in theory. Practically you are bound to face a LOT more. Read BHPian NikhilB's Turbo Civic thread and look at how much effort and time he invested to build it. He built it as a project car, in addition to the fact that he had a lot of data thanks to people who had turboed the same engines abroad. Does the OP have such support?
Most importantly, it's a "daily driver". You can't have it throwing tantrums and leaving you stranded just for the sake of R&D or philosophy.
It's best that the OP either lives with the Punch or sells it and gets a used Nexon Turbo petrol or the likes. As for trying out performance air filters and a stage 1 tune, the former can be given a shot. Naturally aspirated engines don't respond well to tuning and a gain of around 5-10 hp is the max one can expect against an amount of 20-25k. I think it's better to refrain from doing this too.
