Search this Thread | 56,503 views |
23rd June 2023, 13:26 | #16 | |||
Distinguished - BHPian | Re: Anatomy of a Car AC Compressor (clutch/variable) Quote:
At high engine RPM the compressor displaces more volume and cools quicker. Still, when a car is at stand still and the engine idling it must be able to provide sufficient cooling power as well. On modern cars, the clutch will be disengaged at engine start, just to make starting of the engine a little easier. Only after a few seconds, the AC clutch will kick in. Other than that, as I mentioned earlier, on most system the clutch tends to be switched on/off depending on pressure of the refrigerant. Yes, you are correct. My bad, a “senior" moment! It had already been mentioned by another member too Quote:
The clutch would only disengage if the compressor is running with its swathe plate in no-compression for an extended period of time. Quote:
Jeroen | |||
(2) Thanks |
The following 2 BHPians Thank Jeroen for this useful post: | Mu009, PearlJam |
25th June 2023, 20:55 | #17 | |
BHPian Join Date: Apr 2017 Location: Pune
Thanked: 1,257 Times
So, the question of lubrication, wear and tear is more relevant to type B (aka externally controlled ECV type) as the compressor shaft is always rotating with the engine. Most of the latest Hyundai cars available in India are coming with this type of compressor nowadays. Case 1: When the AC system is running: The swash plate is at an angle with the main drive shaft pushing out refrigerant as required which is controlled by an electronic feedback mechanism in conjunction with ECV (electronic control valve) getting signal combined from the BCM, ECM based on the output of APT (ac pressure transducer), thermistor, sun load sensor etc. The feedback loop and circuitry are really complex due to the plurality of various control parameters. In some vehicles, the expansion valve is of cross-charge type (basically known as TXV) where a small bottle is attached to the expansion valve (superheat unit) which is connected in a loop with the condenser output. This superheat unit is a separate circuit and also carries a small amount of different refrigerant which never comes in contact with the main R134a for the cooling system. This superheat system also controls the amount of refrigerant passing through the expansion valve according to the instantaneous cooling demand. A compressor can only compress refrigerant in gaseous state, and the refrigerant carries the lubricating oil in mist form. So when the AC is running, the lubrication part is taken care of well. Now Case 2: When the AC system is not running but the compressor shaft is rotating with the engine. When do we need lubrication? A dynamic system with moving components with some kind of sliding/frictional motion. When the AC is off the swash plate is operating at nearly zero degree angle (orthogonal with the compressor shaft) which is often termed as ‘no flow’ or ‘low flow’ condition. So, which parts inside the compressor housing need lubrication? The first one is the pistons. When the swash plate is orthogonal with the shaft the pistons are having NO to-and-fro motion (stroke) through the cylinders. Therefore, no friction or sliding. Also, most of these piston comes with a thin film of PTFE (commonly known as Teflon) coating. PTFE has very low mu (coefficient of friction) and itself acts as a primary lubricant. If these coatings are damaged somehow no oil can prevent the compressor from a seizure. Hence, with an orthogonal swash plate position pistons are safe from wear and tear. Next, the swash plate itself. Generally, the angle is controlled by the mechanical link of two half ball bearings attached to the surface of the swash plate (one at the belt side and one at piston side for each piston). This has also been pictorially shown by Jeroen sir in the OP. While in orthogonal position the swash plate and the half ball bearings have ‘no relative motion’. The swash plate and the bearing slide with each other only when some angle is to be maintained. Now, the entire compressor housing stores some oil while the refrigerant's static pressure without any flow or compression is equal at low and high sides. In fact, each main component of an AC system viz. compressor, condenser, cooling coil etc. holds some specified oil amount as per OEM chart. What about the drive shaft and pulley? They are in motion with some roller (needle) or ball bearings which are already lubricated (as per bearing spec.) for continuous operation. Moreover, these clutchless, continuous-operation compressors have a built-in fail-safe mechanism. This is achieved by a ‘torque limiter’ or ‘shear plate’. The name itself indicates how it helps protect the drive belt and allied components in case of the onset of a seizure. This ‘shear plate’ consists of some high-grade elastomeric holders and an aluminium plate held to each other, which are designed to shear off and disconnect the drive shaft from the rotating pulley on meeting the condition of excess torque demand than the preset limit. For obvious reasons, the basic visual diagnosis of a kaput clutchless compressor is whether the centre bolt is rotating along with the pulley. If the centre bolt is not moving the ‘torque limiter’ is broken and the compressor is damaged. Hope, this answers your query. | |
(5) Thanks |
The following 5 BHPians Thank Blooming Flower for this useful post: | haisaikat, Jeroen, Samba, SS-Traveller, vishy76 |
30th June 2024, 15:10 | #18 |
BHPian Join Date: Sep 2019 Location: New Delhi
Thanked: 278 Times
| Re: Anatomy of a Car AC Compressor (clutch/variable) I have a few questions which I hope can be answered by the experts. My corolla altis 2014 ac compressor was not working and showed to authorised Toyota workshop and they said, we don’t change the compressor only. The whole ac kits needs to be replaced which includes pipes, condnsor etc and estimate of Rs.1.5 lacs plus taxes. Left with no option, i approached FNG and he replaced the compressor with some other spare ones, not brand new and ac is working fine. But he said that the sensor which is in the compressor has to be byepassed. I want to know what is the purpose of this sensor and byepassing it could cause what kind of damage. FNG says it is not an issue and it’s completely safe. Please advice, if any major issue, otherwise I will not keep the car for long and sell the car. |
() Thanks |
