I own a
Kia Carens since Oct 2022. This is a
1.5 Diesel MT Prestige Plus. I have installed a few accessories, including a dashcam.
Dashcam model: 70mai Pro Plus+ A500S (including rear camera).
Earlier, I had connected the dashcam using the USB charger that came with the dashcam, as the previous accessories shop guy did not have any experience of hard-wiring, and also he made me fear that the warranty may void if any accessories draw power from the car's fuse box.
After using the dashcam for more than 5 months, I don’t like the visible USB cable and sometimes my kid pulls off the cable from the socket. So, I purchased the
70mai Hardwire Cable Kit.
I enquired another auto accessories store (WMQW+V2 Bengaluru, Karnataka) and I took my Carens along with the hardwire kit purchased.
Before starting the hard-wiring work, the shop guy wanted to set an expectation to me that, the
parking surveillance mode never worked on any dashcam that he had installed with a hardwire kit. However, I agreed to start the installation, as I wanted to get rid of a visible wire.
Moreover, I assisted him during the installation by referring to the manual.
https://xm.cz/data/files/70mai-hardw...n_compress.pdf
The following are suggested in the hardwire manual
- Connect the power cable (red) to the regular electric fuse with an output voltage of 12-30V and output current of 2.4A inside the fuse box.
- Connect the ACC signal cable (yellow) to the ACC power fuse inside the fuse box.
- Connect the ground wire (black) to the negative terminal or ground of the fuse box.
Considering the above points from the hardwire manual, I have side suggested the shop guy to connect each wires to the Kia Carens’ driver side fuse panel.
- Red wire was connected to Multimedia 20A fuse
- Yellow wire was connected to ACC 10A fuse
- Black wire was grounded
After which, the dashcam gets powered-on when the car gets ignited. However, the
parking surveillance did not work, as mentioned by the shop guy. Also, the installation was done along with my assistance, I did not want the guy to rework anything.
I had the dashcam without parking surveillance working for a few days. But, I felt that I paid for some feature and I wanted that feature should work.
I was going through the 70mai hardwire kit manual and Kia Carens fuse-box description for a few times, and I was out of clues.
Then I referred NEXDIGITRON YT tutorial and I learned that the RED cable should be powered 24/7 and YELLOW should be powered only when the car ignition is on.
I had revisited the Kia Carens fuse-box manual and could not find any fuse that is mentioned as 24/7 or always on power supply.
I understand that the
DOOR LOCK 20A (
) fuse must be an always powered-on module. The
ACC 10A fuse must be one of the fuses that gets power only when the car is ignited.
Based on the current understanding, I myself have re-connected RED cable and the current cable connections are as follows:
- Red wire is connected to DOOR LOCK 20A (
) fuse - Yellow wire is connected to ACC 10A fuse
- Black wire is grounded
This rewiring helped me in enabling the parking surveillance mode and it works as expected. I was able to simulate some events and checked the parking video was recorded.
I am not going to use the parking surveillance feature regularly but occasionally during when I park my car in a public parking slot max. 10h continuously once in a while.
The reason I wrote this post is to get fellow users suggestions, as I have made my own decisions based on the little DIY skills I have to make the parking surveillance work.
Please suggest,
- Whether I should reconsider red the wire connection i.e. get the always on power from a fuse other than DOOR LOCK 20A (
) fuse. - Does connecting dashcam to the Kia car's fuse box affect Kia India warranty?
