Old 12th October 2012, 23:23   #1216
Thanked: 324 Times
Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by raycers_honda View Post
Has anyone put any ancillary lights in the cabin. The standard I have are the roof light and the reading lamp at the back.
In my Ohc I have put under dash lighting. I'm looking for something to replace the roof lamp. Maybe change the bulb or change the fitting etc. I'm not looking for some cheap stuff like in the taxi's. I want something which would look neat and of good quality.
If any of you'll have any ideas or done anything similar do post some pics up here.
A little late.. but what the hell.. been crazy busy lately. As Desmosedici said.. I too swapped the original for the white LED's for the roof light. It is the best alternative to the original. Brightness is better than the stock lamp.. but not all that bright... prolly cos the covering glass/plastic is not clear but semi opaque in my car. Basically.. it's an improvement.
Also they're small enough and take up less than the original lamp does.. so if your electrician/mech is good & you find that a single set of the LED's don't do it for you.. just get him to connect 2 sets together & LET THERE BE LIGHT!
Vandit is offline   (1) Thanks
Old 13th October 2012, 19:15   #1217
Any idea how much should a wiper motor cost?
dhiman is offline
Old 13th October 2012, 21:21   #1218
raycers_honda's Avatar
Thanked: 695 Times
Hello there, are you sure your motor has gone kaput, because I thought mine had gotten spoilt too.Until the first time they checked it was the link arms.
The second time I thought it had gone kaput again. But then a thorough service job and it was back to normal.
I reckon it should cost anywhere between 2.5 to 3.5. If budgets a constraint then go in for a used one which normal comes with a six month warranty by word of mouth.
But first do the homework. It might save you a couple of hundreds here and there.
raycers_honda is offline
Old 14th October 2012, 08:16   #1219
johnda's Avatar
Thanked: 19 Times
Originally Posted by di1in View Post
I lost mileage from 11 to 9.
contemplating getting a new free flow from Raj himself.. his FFEs have a note that I am addicted too..
All the best on planning a new FFE, Yes that note is what we die for, mine has an exclusive low end and a quite purr that is too good.. try and see if you can work on the FE as well, I'm guessing that 9 is a bit low.. do other Vtecs with FFE give only so much?
johnda is offline
Old 14th October 2012, 09:20   #1220
infotech58's Avatar
Thanked: 256 Times
Originally Posted by KSM-Vtec View Post
Thanks Bro!
I have identified a really good CNG installation guy and am hopeful that he knows his job well.
Are your efficiency figures with 100% AC in traffic? If yes thats great!
Looking for more feedback.
Did you CNGed it yet?
infotech58 is offline
Old 14th October 2012, 12:30   #1221
Actually, when i switch on the wiper, there is smoke coming from the dashboard. Plus, the speed of the wiper at the highest setting has also reduced considerably.
dhiman is offline
Old 14th October 2012, 12:32   #1222
di1in's Avatar
Thanked: 293 Times
Mine isn't a VTEC, it's a regular 1.5 Exi.. previously I used to get 11 with FFE in total city traffic runs with AC on..
di1in is offline
Old 14th October 2012, 12:47   #1223
Thanked: 695 Times
I think first you should tell the mechanic to get it serviced and also let them check your wiper link arms. If your motor can't be fixed you might have to replace it. Also open the bonnet and check the exact location of the smoke. If possible take pictures.
Old 14th October 2012, 19:49   #1224
ankitahuja's Avatar
Thanked: 99 Times
Last week my OHC started making a strange sound when changing gears or sudden foot removal while accelerating. It sounded like a small BOV but I knew something was wrong. Friday night a more grinding/clanking/cluttering sort of sound started coming from under the hood. I checked and could it point it to the pulley, though I checked under the body and everywhere else too to rule out other possibilities.
I slowly drove the car back home (from office) which is about 5 kms. By this time the sound had peaked.
Called the mechanic home who saw and said the timing needs to be opened, the pulley is the culprit and after opening is when we can say what the matter is. Could be just a loose bolt or if the bearing etc is broken. Said its OK to drive verly slowly and get the car to them (3kms away).
I took the car there and after opening up we saw that the main pulley (on which all 3 belts are placed) had massive play and was the culprit. Ok, so then the bolt that held the pulley refused to open! Saw that it would loosen up to a stage and then started tightening again! He said that if I try harder, the bolt will possibly break and then the engine will have to be brought down - opened to get the new bolt fitted by the lathe guy etc etc etc. Tried heating up the bolt for it to expand and loosen etc too but then Nightmare.. it broke!
The pulley fell down and 60% of it's grinders/teeth were polished :(
She's being operated upon now.. More info later.
ankitahuja is offline   (1) Thanks
Old 14th October 2012, 20:33   #1225
Thanked: 852 Times
Chances are, the threads in the crank are destroyed due to the hack job done by the mechanic. I'm pretty sure the notch that the woodruff key sits into is destroyed as well. No other reason why your crank pulley would be wobbling.
If the crank is damaged, which I believe it might be, you are going to end up spending quite a bit of money.
pranavt is offline   (1) Thanks
Old 15th October 2012, 11:29   #1226
ankitahuja's Avatar
Thanked: 99 Times
Thanks, Pranav. I have a lot of questions so will be calling you when you said.
The mechanic has pointed the problem out to an uneven and incorrect bolt fitting/tightening when I got the timing belt+bearing changed last year. Says it left the pulley tight but not in the correct position and the threads in the pulley have vanished and caused the wobble, including the play and the unopenable bolt.
Old 15th October 2012, 16:13   #1227
Desmosedici's Avatar
Thanked: 627 Times
Even i had felt that my wiper motor was gone. But got the wiper area opened and saw that lot of leaves had jammed the arms. Cleaned it up and used WD40 and some diesel to clean it up, then used some oil to keep it lubricated and it works fine now. Got all this done by the small neighbourhood garage for 100 bucks.
Desmosedici is offline
Old 16th October 2012, 15:15   #1228
Any recommended local workshop/service center to fix the O2 Sensor at Cochin. I bought it from amazon and HASS refuse to fix it as the part is purchased from outside, how can i buy the part from them because they charge 18 k and an original Denso product from Amozon shipped to my Cochin address for just Rs 3300 including the shipping + Import duty.
vinu_pm is offline
Old 16th October 2012, 15:32   #1229
di1in's Avatar
Thanked: 293 Times
Perhaps you could search around in the TBHP directories: http://www.team-bhp.com/forum/other-cities/
*Update:
Here's a search for the one's in cochin:
http://www.team-bhp.com/forum/search...rchid=16224927
Hope it helps!
di1in is offline
Old 16th October 2012, 18:25   #1230
kutlee's Avatar
Thanked: 233 Times
Vinu, if you are in Blore, take to any mechanic and will fix that for you for 100 bucks. Else you can buy spanner and DIY.
kutlee is offline   (1) Thanks
