Re: Performance Mods for Tata Revotron engines Quote:
Originally Posted by CannedShroud This makes sense, but I would still like to understand if it is possible to get the Altroz iTurbo engine to meet the same/similar spec of the Nexon petrol.
My understanding is that these engines are very much the same and getting the same power output from them should be possible.
Please share your thoughts on this. | Quote:
Originally Posted by CannedShroud Hi, thanks for the reply..
I'm aware of the transmission differences of the iTurbo and the Nexon.. And I understand that the TA65 is not rated for the higher torque while the TA6300 is.
But I belive the number Tata is quoting is at the crank? And not the wheels. So the detune of the engine is still valid right?
I do have a tuned iTurbo (albeit not a stage 2). But the numbers from a tuned Nexon are still higher than a tuned iTurbo.
What are your thoughts on this? Is there anything else I'm missing? |
This is very debatable!!!
Once I was having a detailed discussion with the DET guy regarding dyno test (The topic was between XUV 300 and Nexon - As I always said XUV 300 is powerful and Nexon is too lethargic). He said Tata have tuned it like that and these are hard coated, but he also mentioned that once you open up the ECU maps, the revotron engine is capable. Now coming to your point - Altroz is lighter by 200kg than Nexon hence the detuned was given, and on roads, the power output is very similar to Nexon. If Tata would have given the same state of tune along with TA63 box then Altroz will beat the I20 NLine and compete with Polo GT.
I think a stage 2 remap with Iridiums, modified intake, exhaust and don't know whether transmission swap will be possible.
In Kolkata, we are having some setups where they are doing some insane tuning jobs. (Still not comparable with south folks  )
Can you share the difference after your stage 1 tune? |
