Old 1st November 2022, 20:32   #1
Problems with aftermarket LED tail-lamps
Hello Experts
I have a Hyundai Venue in which i have upgraded the tail lights to Custom LED set. Of late they are acting wierd and that too only on the right side. Here is the scenario
1. When only on battery power both the lights light up perfectly fine and are stable
2. When I turn on the ignition, the right side light parking bulb starts running in the initial sequence and keeps on doing that.
Here is link for the scenario when car is on engine power
Right Side
Left Side
PhrozenWire is offline
Old 3rd November 2022, 07:51   #2
TN20CQ5187's Avatar
Thanked: 57 Times
Re: Problems with aftermarket LED tail-lamps
Hi, this looks like a led issue. You can probably go back and check with where you have installed these from.
TN20CQ5187 is offline   (3) Thanks
Old 3rd November 2022, 09:16   #3
Thanked: 4,909 Times
While LED's are very reliable compared to incandescent bulbs if given the proper voltage/current, the practical truth is that the electronics that do that are extremely spotty because of cost or design issues.
If you go through YouTube teardowns of LED bulbs, you'll find most Chinese units have one of more of issues like the use of failure prone Chinese brand capacitors probably using capacitor plague era formulas, insufficiently rated heatsinks and resistors. Insufficient voltage regulators which do not protect the LED from voltage variations and sometimes currents higher than recommended to achieve higher brightness.
This is a risk you'll face with even known and established brands. You should read about the plight of some Cadillac owners who can't use their cars because their taillights died prematurely and replacements cost as much $2-3k, and tail light is considered essential safety equipment and you can't operate a car without it. It's bound to be much worse for generic stuff.
greenhorn is offline   (4) Thanks
Old 3rd November 2022, 10:50   #4
IshaanIan's Avatar
Thanked: 7,709 Times
Infractions: 0/1 (7)
Where did you buy the lights? If online perhaps email the seller if you got them fitted in a store then go back and ask the installer. This is why it is best to stick to people like Lumiere concepts for such stuff where you might spend quite a bit but atleast you will get service support for these kind of things.
IshaanIan is offline
Old 3rd November 2022, 16:35   #5
I purchased it online and got it installed from a known accessories store. What surprises me is that on battery they light up just fine and have no issues.
He has no clue and asked me to check the metal case resistor which is attached. Though the resistor is not for these lights but for the indicator lights to run in a matrix style sequence.
Last edited by Axe77 : 15th July 2024 at 23:11. Reason: Merging back to back posts.
Old 3rd November 2022, 18:48   #6
Thanked: 2,377 Times
It could be an issue with the controlling software / hardware and not the light as such. If you have the option and feasibility, try swapping the two lights to check if the behaviour persists. If so, issue with controller, else issue with led. Alternately try putting another led on the affected side, to see if the behaviour changes or stays the same.
ajayc123 is offline   (4) Thanks
Old 5th November 2022, 12:48   #7
Thanked: 69 Times
If possible check voltage at the tail lights connector on battery and with engine running. With engine running the voltage might be slightly more than 12v and this is affecting the led controller.
ArijitGupte is offline   (1) Thanks
Old 9th November 2022, 20:21   #8
So I tried the different methods as listed by all namely,
1. Swapping the lights LH to RH and vice versa, same issue
2. Checking voltage, stable at around 12.2-12.4 V
3. Checked wiring, no issues
4. Put stock lights and they work normal
Settled for stock for now till I further check the LED
