Originally Posted by src Honestly neither do I want to sound cynical nor I want to freak you out but my AMT Nexon was cancelled on the insistence of my TATA Service Advisor.
Had driven a Manual Tiago for almost 60k KMs from Aug-16 to Feb-21 without any issues.
Experience was so good that I wanted to upgrade to Nexon XZ+ but my ASS Advisor strictly advised me to stay away from AMT as he was certain about the failure after 3 years when EW also don't cover gearbox.
Anyway eventually I bought the City CVT for peace of mind.
Yes fact is AMTs are unreliable in long run and OEMs don't want to agree and shy away from their responsibilities.
Anyway DM me if it is in Bangalore and let me see if something can be worked out. |
Your comment gave me a a shudder as soon as I read it. Are you sure the extended warranty won't cover the said parts? I was at my Tata dealership in Agra yesterday, and this is what they gave me (image below).
I think the text isn't very legible after uploading.
Here is a transcript :
ANNEXURE II
Engine
Cylinder head, head gasket, oil pump and drive, crankshaft, flywheel and ring gear, timing gears, belt and chains, camshaft, cam follower, valves (excluding burnt and pitted valves), valve gear, pistons, connecting rod, gudgeon pin, distributor drive, inlet and exhaust manifolds, bore/liner, turbo, intercooler units where factory fitted, variable geometry Turbocharger, EGR cooler, Cam box, Auto tensioner.
Clutch
Clutch pressure plate, clutch disc, release bearing (Any breakdown covered up to 50,000 kms from the 1st km) master
and slave cylinder, clutch cable (failure due to worn or burnt clutches are not covered), Clutch switch, clutch HP pipe.
Transmission/AMT automatic transmission (if fitted)
Internal gears, shafts, synchromesh rings and hub, bushes, selector forks, drive chains, gear lever and bushes (failure
due to worn or burn out clutches and bands are not covered), Gear shift cable, reverse switch. Torque on Demand. AMT
and its internal parts Cooling System
Radiator, water pump, thermostat, engine oil cooler (failure due to external damage or corrosion is not covered), Steering System Rack and pinion, steering box, column, shaft bearings, couplings, power steering pump, pressure pipes, reservoir. Electric power steering system and its component.
auxiliary tank.
Final drive Crown wheel and pinion, differential gears, hub and hub bearing. Rear Disc brakes/Drums Front wheel drive
Drive shaft and couplings, constant velocity joints, hub, drive flange, transfer case.
Fuel System
Fuel pump, pressure damper, auxiliary valve, overrun cut off valve, deceleration valve, tank sender unit, Fuel rail, fuel pressure regulator, injectors, Assembly fuel injection pump, high pressure pump, common rail, high pressure pipes and pressure hoses, throttle body, continuous variable cam phaser unit. Fuel pump calibration & rectification for faults.
Brake System
Servo, master cylinder, wheel cylinder, diesel vacuum pump, callipers, Discs (excluding brake pads/liners/drums) upto 50,000 kms, handbrake lever and ratchet, ABS ECU with modulator, wheel speed sensor, brake pedal switch. Suspension
Shock absorbers, bush, control arms, upper and lower wishbones, springs, sub frame. Any claim is limited to 50,000 k
ms only from the 1st km.
Casings
Should failure of any of the components covered result in damage to the casings, then they will also be covered and will
constitute part of the maximum claim liability. Exhaust system
Secondary air pump, EGR valve, EGR actuation system. Intake System
Assembly throttle body (which includes map sensor, throttle position sensor and idle speed control valve). Air mass
flow meter air temperature sensor, cam angle sensor, Air intake throttle, oil separator and PVC valve. Ignition System
Ignition switch, Immobilizer ECU.
Evaporative Emission Control Fuel tank cap and relief valve, Glow Plug (upto 50,000kms), fast idle control device, cold start valve
Engine Management System Water temperature sensor, crank angle sensor, vehicle speed sensor, distributor, ignition coil, ECU, cam sensor knock
sensor, lambda sensor, PDA position sensor, rail pressure sensor, accelerator pedal sensor.
Electricals
Starter motor and solenoid, alternator, wiper motor and washer motor, window motors, fan motors, panel switches and instruments, driver information system, body control module, ambient temp sensor, Rain light sensor, Blue tooth box. Rear view camera, window winding controller. Wiring harness not covered.
Air Conditioning Compressor, condenser, evaporator and clutch magnet, AC control panel, Thermal Expansion valve, blower motor, heater unit, pressure switch. Automatic climate control unit. As for such parts as tyre, batteries, seats, music systems, chassis frame, rear dead axle, body parts
etc. this warranty shall not apply
This warranty shall not cover normal wear and tear or any inherent normal deterioration of the car or any of its part arising from the actual usage of the car or any damage due to negligent or improper operation or storage of the car. This warranty shall not apply to normal maintenance services viz. oils & fluid changes, head lamps focusing, fastener tightening, wheel balancing, tyre rotation, adjustment of valve clearance, fuel timing, ignition timing, wiper blade/ rubber, distributor cap, HT leads etc, and consumables like bulbs, fuel filters & cll filters etc, and normal deterioration of sensory feels ilke noise, touch and texture of particular component.
