Re: Cooling system failure in my VW Polo GT TSI I own a 2018 GT TSI with 74000 kms on ODO. Yesterday, on a short 4 km temple visit, car showed coolant temp light blinking with temp increasing up to 125 deg C. I checked the coolant level and it was perfect, Fan was also running. I suspected Thermostat gone kaput. Rested the car overnight. Started in morning and let the engine warm upto 90 deg C. Then did a 14 kms test drive to check if the error is repeated and nothing. Car is running perfect. Could it be the coolant temperature sensor malfunction? But then how come it shows gradual temp increase in instrument cluster until 90 deg C? I have a 400 kms long drive day after tomorrow and service center is about 60 kms from where my car is currently. Is it safe to drive to service center to get it checked? VW technician says a long drive is required since thermostat cant be diagnosed by scan. Its a trial and error method in case of thermostat. If Thermostat is gone then it should not have run normal for today's 14 km test drive. Any help and guidance shall be highly appreciated. |
