re: Is the Indian R18A1 Honda Civic flawed? Quote:
Originally Posted by IshaanIan Should be able to delve deeper and find out exactly which engine and which batch of cars made where had faults but if you cannot, then you can simply go for a FL post 2009 model if you are worried about such flaws. Another option could be a Kizashi it uses the J24B Suzuki motor with a block that was rated to handle upwards of 500bhp and loads of space in the engine bay since it was designed to house a 3.6L GM V6 so it also might be a good car to extract performance out of although there will be far less documentation available on the internet for modifications  |
Thanks, I will consider the Kizashi and look into it further.
The consumable spares seem to be available on boodmo for the most part, and it does seem like a good deal.
Do you have a source on the 500hp figure?
BUT, there seems to be a recall with this too https://static.nhtsa.gov/odi/tsbs/20...59469-0001.pdf
The ones for sale on sale seem to be later models than the ones afflicted, and they don't mention which region/batch had these issues either :((
The only reason I'm worried is because due to lenient laws, I assume the manufacturers can get away without issuing a recall in India (and perhaps even continue selling it for another year or two?)
As for finding more information on the batch of cars that had faults, Honda hasn't even officially issued a recall, they've instead issued extended warranty on the blocks in the US (although it has expired now), and the blocks seem to be cracking on high mileage cars (100,000 km+), so even over there, many people are left with cars with engine blocks prone to cracking. Quote:
Originally Posted by ranjitnair77 I had a 2007 Civic for a decade and my information is probably anecdotal, but I haven't heard of engine blocks cracking. Here are some common issues that were prevalent in many Civics of that vintage. - Engine mount issue. Mine were replaced under warranty.
- Takata airbag issue. I had to get both the airbag inflators replaced under a recall.
- Power steering fluid leak.
- Comfort-oriented, boat-like suspension that's just not suited for spirited driving.
Thanks, this is very helpful! Looks like none of the issues are particularly serious.
Can the airbag inflators still be replaced under recall? I found a Honda article about it, but they don't state when the recall will end. https://www.hondacarindia.com/media/...ators-in-india |
