Re: Mahindra Di-Turbo fuel pump issue Hello Krishna,
This seems like a case of starvation of fuel and will depend on the consumption. Idling will most likely be normal and as the speed increases, the noise will amplify and after a certain speed drop in power will be very much noticeable.
Hope the fuel lines and filter has been checked and there is no issue with that.
Further you can check the fuel tank condition from inside. I am not sure what material is used for fabrication of the tank, but in case of a metallic tank, the debris from corrosion over a long period of time starts blocking the filters frequently, specially when the vehicle is run over the rough terrain, causing sloshing of fuel in the tank, which brings the settled particles to suspended in the fuel and an easy entry into the filter.
Running the engine with this condition will cause more wear on the fuel pump and will require replacement.
In case you plan to fit an electronic booster pump, please clean the complete fuel system right from the tank to engine and the return line back to the tank.
Hope that helps. |
