HCIL says a cracked engine mount is pristine - A follow-up post to the Engine mount woes.
As suggested by the replies to my initial post, I got in touch with another Honda ASC and explained the situation to them. To them, the fluid leak issue and the extra vibrations were something that was not reported earlier. After taking a test drive, they acknowledged that there was a peculiar jolt when releasing the accelerator. Also, they informed me that they haven't noticed the fluid leakage on the engine mounts so far since no one has pointed out this as an issue.
I was at the ASC just to get the car inspected. So no service request was registered. Since the issue was already escalated to Honda and denied warranty claim from there, I asked them to see if the jolting and fluid leak was found in other cars as well. The floor manager at the ASC assured me that he will check this and share an update in a week. The service manager at the dealership had a diesel Amaze with similar age and Odo reading as mine. So, he said, it can be used as a reference. However, we couldn't check that car as it was not present there that day.
A week later, I got a call from the service manager of the ASC and he said that the fluid leakage was present in all the cars they checked and the jolts were present in all those cars, including his own car. However, since Honda has declared that fluid leakage in engine mounts is no longer an eligible criterion for replacement under warranty, they can't do much about it but
if I am able to record anything audible that was caused due to the jolts and extra vibrations, they can present it as proof for warranty claim.
Unfortunately, this was quite hard. There was a tuk-tuk sound now and then but it would need studio-quality setup to get it recorded. Also, the noises during gear shifts could be eliminated by releasing the clutch very slowly so, the chances that they would discard this with the claim that "
it is because you release the clutch too soon" were very high.
This wasn't an unexpected outcome as by this time Honda themselves has even stopped replying to
emails.
Since I wanted to get over with this headache, I decided to change the part as a paid service and asked the ASC whether they can arrange for the same and they gladly accepted. I decided on the paid replacement as I was optimistic about the improvement in the ride quality from the past two experiences. Also, there was no point in expecting something fair from HCIL as they were just blindly
denying the issue.
Finally, I got the engine mount replaced on January 8th the cost of replacement including the labor charges were Rs. 5209. The cost of the engine mount is Rs. 4644.
Brand new Engine mount Brand new Engine mount - No Leakages Price details and the box labels Old Engine mount
Since it was a paid replacement, the old part was given to me. I carried out a casual inspection of the old part and these are my findings.
- The engine mounting has a visible crack on its enclosure.
Crack on the engine mount
Crack on the engine mount - Close up
Crack on the engine mount - Zoomed
Crack on the engine mount - Zoomed - Dust accumulation
I don't think this is something that is acceptable for a component that shares the weight of the engine. This clearly indicates the quality of the inspection and diagnosis carried out by the first dealership and this was the reply from the Senior Escalations manager when I approached Honda.
There is no abnormality is the vehicle and it is thoroughly inspected by the dealership in consultation with HCIL technical team.
(No, I didn't make any typo, the reply is as it is.)
- The leakage appears to be all around the axis of the mounting and above the flap that covers the hydraulic chamber. On the flap, there is a wax-like substance which I believe is the residue of the fluid leakage.
Fluid leakage pattern
Wax like substance found on the flap
I was not able to produce any further fluid leak by applying force on the mount. However, there seem to be new fluid leakage patterns since I first visited the ASC with this issue. That time they had wiped the mounting clean and now there are new fluid stains. So, this makes me believe that there is indeed a LEAK.
Bottom line:
The crack on the engine mount was a surprise for me. The service center's audacity to declare the engine mount as non-faulty without even physically inspecting it properly and then
Honda Senior Escalation manager parroting the ASC's version when the issue was escalated clearly shows the state of Honda and Honda ASCs. Honda is no longer the reliable, customer-friendly Honda that it once was
Since the Amaze's engine mount is manufactured only by Honda, even with the new engine mount, I am bound to face this issue sooner or later. So, spending 5k+ on engine mounts is going to be a periodic expense it seems. Or, I have to learn to live with it
which I don't think is quite easy.
I hope more Amaze owners came up with this issue and force Honda to release a revised part.
