Re: Skoda Rapid Looks slightly tilted to the right side, Quote:
Originally Posted by deepak_fletcher What would be the issue if not the suspension? |
Firstly check tire pressures, and fill to correct spec, and load the car with half tank of fuel.
Get a measuring tape, measure from ground to fender, or wheel hub center to fender, note down all the readings.
Whichever side is lower or has deviation check the control arm bushes on that side firstly, you can check these by turning the steering away from the wheel that needs to be checked.
Check the subframe as well and the strut mounts. Do this yourself if you know how to verify, else take it to FNG, just for a second opinion about ASS.
Happy Motoring! |
