Re: Aircons! Demystifying the car air-conditioning system, Part 2 Quote:
Originally Posted by chiranjitp Are there any positive effects on the longevity of the AC components if the AC is not run at full blast? |
Thank You @chiranjitp. In my earlier cars, a 2003 and a Toyota Corolla, I've observed the AC compressor cutting off faster if the blower speed is lower. The compressor cycling (on - off - on) is based on the thermistor reading of the evaporator skin temperature. My first thread on the topic has details of how the compressor cycles on and off. So, it is good if the AC is not run at full blast. Quote:
Does the compressor cut off more frequently if the temperature is set on the higher side? I read somewhere that to attain a higher temperature, the climate control system would mix hot air along with cool air, rather than switch off the compressor for a longer interval
Unfortunately, in cars' Automatic Climate Control systems, this mixing does occur. The compressor cycling will continue to be determined only by the thermistor. Quote:
Many people in India would run the AC on coolest setting, manually switch off the compressor when things get too cold, then again switch on the compressor. Does this method help in fuel saving?
Nothing wrong in doing this compressor switch off and switch on with the blower still running. But this might result in the cabin temperature going up beyond intended if the compressor isn't started on time.
I'd say, keep the blower speed at the optimum level(the lowest required to keep the cabin just cool), and the temperature setting at the lowest. The compressor will cycle on and off just right. If you see, in manual AC cars, the temperature knob is set at the lowest in the blue range.
For home ACs, which are just ACs and not HVACs, I set the temperature at 26 degrees C in summer. In winters, I run the ACs 10 minutes a week just to keep them roused.
One tip on AC care that I missed mentioning in my earlier post - clean the AC condenser every 6 months or so using a low pressure water spray so that it works efficiently. At a water wash station, the gun should be approx. a foot away so that high pressure jet doesn't damage the condenser fins. In most cars, the front grille has to be removed for access to most of the condenser area. |
