re: Car starting problem only in the morning There are two ways to diagnose the problem.
1. What are the after market electrical and electronic accessories that are installed in the car? Suggest to remove everything and keep the car stock.
Try if the car starts in the morning normally as stock. If it starts in one go, then, one of the after market accessories is the culprit.
If step 1 doesn't work, then
2. Remove the battery terminals in the night. Connect them in the morning and start. If the car starts normally, then, it is definitely not battery issue but some stock accessory or circuit installed by manufacturer is causing the leak.
If the car does not start normally even after disconnection in the night, then the battery is the culprit OR the alternator is not charging the battery properly.
Conduct the entire experiment after charging the battery fully in the night (i. e, at least 2-3 hours drive before resting the car in night)
