Summary
A Logan 1.5 DLX that I was travelling in refused to start after a brief stop. The issue that came up was rather strange, but we managed to fix it and were on our way in 2 hours. Read on..
Why the trip?
Four of us were headed to attend a wedding in Erode, and we decided to do the quick day trip in a family friend's car - a 2009 Logan 1.5 DLX that had done 1,60,000km.
We've used this car on 2 trips earlier and found it very reliable and comfortable. However, what we were going to see was reliability going down the drain due to a simple design issue, that almost left us stranded.
A morning well spent
We reached the wedding venue in Erode at approx 9:20am and what impressed me was the acres of space that this venue had to offer - the hall was big, the dining area bigger, and the parking, too big and open for an old set up.
After being part of the festivities associated with the wedding, a sumptuous banana leaf spread, and
Jeera Panneer soda as the cooler, we left Erode at approx 1:45pm for Karur.
The
Panneer Soda point closing down at 1:30pm
Wedding Venue - pictures of the parking area
We reached the outskirts of Karur at 3pm, met up with a relative briefly, and were ready to leave after a cup of coffee.
Logan wouldn't start
At approx 3:45pm, we got into the car, the friend (owner of the car) fired the car up, and just as he was going to slot the car into gear, the engine stopped, and would crank but not fire thereafter.
He opened the hood, but there was no apparent defect. However, as the primer bulb was pressed, something was seen dripping from under the right front - it was diesel. Stop pressing the bulb and the dripping would stop. When I looked under the front, I could see a black thingy with 2 probes connected to a coupler, and figured out that this was something that had come off the fuel filter. I tried fixing it back but to no avail.
Fuel water detector sensor threaded portion broken
I then got two woven sacks to lie down on, and inspected the front underside, and that is when I discovered that this sensor had actually broken off from its threading and was dangling - what a ridiculous design, where a plastic part was installed at the bottom of a filter, without designers thinking of what would happen if this failed !!
View of the fuel filter from beneath
Diesel dripping from the filter - you can hear the friend speaking in the attached video. He was trying to suggest cutting out a portion of a pencil eraser and pluging it into the leaky bottom
The Fuel System
Typically, in a diesel car, the line up is as follows:
Fuel pump in tank -> Fuel primer bulb (eg.Renault) OR Hand pump (most other diesels) -> Fuel Filter -> HP pump -> Rail -> Injectors
In a diesel car, a leak anywhere from the fuel pump to the injectors can cause loss of prime (air in the system). The engine would not fire since the HP pump would not develop the required pressure. Yes, leaks in the high pressure pump and discharge are quite unlikely since this has metallic pipes and pipe joints. Leak prone areas are rubber and plastic parts.
Solutioning
I then evaluated some ways to get out of this issue so that the car could be started up and we could be on our way. The following options were considered:
1.
Tapered rubber plug to just plug the opening at the bottom of the filter - rejected it because it wouldn't stay put and the slightest vibration and the plug would fall off
2.
Rubber cap to cover the entire surface where the sensor would be mounted on the filter - thought of some rubber cap but knew that would also come off
3.
M-Seal to cover the same surface as in point no.2 above, but here the challenge was to ensure a perfectly dry surface so that m-seal could set properly in 30 minutes or so
3.
Replace the fuel filter and sensor - that would require a technician plus we were not sure if the parts were readily available
Solution implementation
Just as we were evaluating options, a technician who was called in by someone closeby appeared in 15 minutes. I explained the issue to him and he said M-Seal would definitely work provided the surface was dry. Some M-Seal was available close by, and so that was procured. Meanwhile, the technician went to check if the sensor was available. I knew this was a small town and so the chances of the part being available for the Logan were next to Nil.
Diesel, in the meanwhile had stopped dripping, indicating that the filter was totally empty. The M-Seal mix was prepared and applied after ensuring that no diesel residue remained on the filter bottom. The mix was allowed to set for 45 minutes.
The technician arrived and, as expected, drew a blank and said that the sensor wasn't available anywhere. However, he inspected the M-Seal applied and said that it had set and would work for sure. He then just actuated the primer bulb and asked my friend to start the car. It fired up without fuss, and we were now sure of getting back home. The sedimenter warning light was on on the dashboard as the sensor had been de-coupled but that was expected. We got back home safe, although 2.5 hours late.
Leak fixed with M-Seal - note that the sensor is now decoupled
Good Samaritan technician
The technician, Kumar, was an angel - the type that we don't see these days; young bloke maybe in his late-20s, and just asked for a nominal service charge of 200 bucks since he had to come from his garage which was 4 kms away. Had he not confirmed that M-Seal would work, I might not have tried that solution.
Next Steps
A new fuel filter with sensor has been ordered, and will hopefully ensure trouble free performance for many years. The only way to prevent this issue from recurring is to modify the filter design to prevent this sensor from being a bottom fit.
LFI (Learning From this Incident)
1. All owners of the Duster, Scala, Sunny, Logan, Verito, Pulse, Micra diesels - beware of this sensor. It pays to keep a spare filter-cum-sensor combo handy. I also see some filters with just a drain cock beneath- not sure on which models this applies.
2. Ensure that you inspect the fuel system througly before setting out of town - you never know what can surprise you
3. Keep some adhesive, and M-seal handy
Fuel filter and sensor drawing on the parts catalog
The Water detector sensor - infamous now
The fuel filter-cum-sensor combo (OE Part No.6001552226)
Fuel filter with only a drain cock
