Old 31st March 2010, 16:47   #16
007
007's Avatar
Thanked: 218 Times
EGR is basically for taking care of the emmisions at the idle ( though it helps at other engine speeds also).
In simplest form it takes out some of the exhaust gases & feeds it back to the intake ( Thats why EGR - Exhaust gas Recirculation).
Though it helps to curb the emissions, it do dilutes the charge (hence the power too) & also causes some problems related to the carbon deposits in the intake (near throttle body area)
Most of the engines today have it.
007 is offline
Old 31st March 2010, 16:50   #17
tsk1979's Avatar
Thanked: 23,484 Times
Disconnecting the EGR had no effect on anything at all, it was done on a trial basis to see if EGR was faulty. anyways, EGR was replaced with larger dia EGR as part of retro get rid of krrr noise, but thats another story
tsk1979 is offline
Old 31st March 2010, 17:06   #18
SPIKE ARRESTOR's Avatar
Thanked: 1,545 Times
The basic intention of using an EGR is to reduce the NOx emissions which occur at high engine temperatures. As the exhaust gases are already burnt, they act as an inert gas and reduce the amount of oxygen available at the combustion chamber, the net effect is that it reduces the peak combustion temperatures, thus resulting in lesser amount of NOx production. Generally, the duration for which the EGR opens and closes depends on the water temperature.
Spike
P.S. If the EGR is blocked, you can feel a slight improvement in power.
SPIKE ARRESTOR is offline
Old 1st April 2010, 04:48   #19
ph03n!x's Avatar
Thanked: 6,158 Times
Guess you are the only one (until now) who has had the EGR at least temporarily removed. I read that there will be an increase in power and fuel economy with EGR reduced (Wiki says fuel economy may increase by as much as 25%). What are your comments on this? Is it advisable to chuck this one out?!
ph03n!x is offline
Old 1st April 2010, 08:47   #20
Thanked: 46 Times
I have had the EGR removed and replaced from my Laura once. I didnt feel any noticeable improvements in power delivery. I had to pay a ton of money for the same too.
ronin is offline
Old 1st April 2010, 09:04   #21
jav
Thanked: 66 Times
Had disconnected the egr in my indica a while back, the only difference was a little bit more pull while releasing clutch in first gear without pressing accelerator.
Well as for the mileage part i actually had lower kmpl with egr off, dont know why
now the egr is back on but tweaked slightly to cut off at earlier rpm
jav is online now
Old 1st April 2010, 14:26   #22
Thanked: 463 Times
When my safari had that idle surging problem, they disconnected EGR for some time to see if problem goes away. Guess what, no service light
Did they completely remove it, including its vaccum pipes or they unscrewed and left it hanging ??
If left hanging, its working, so no impact on the sensors. If removed completely I am surprised on why no SL.
dadu is offline
Old 19th May 2011, 12:05   #23
satish_tns's Avatar
Thanked: 116 Times
re: EGR system - What's it purpose & when does the EGR valve open/close?
Apart from the power increase, milage increase and specially avoiding the carbon settling on the EGR valve by removing EGR, are we not violating the emission norms by removing EGR? Just had this thought in mind!!
satish_tns is offline
Old 19th May 2011, 12:30   #24
By removing EGR, you are violating emission norms specially NOx which is produced at higher temperature and engine speeds.
Spike
Old 5th March 2013, 10:23   #25
Thanked: 3,638 Times
My EGR seems to be over-supplying the exhaust gas, and this has been flashed by my Diagnostics computer. I don't wish to outright block the EGR; so what are my other options?
roy_libran is offline
Old 5th March 2013, 10:57   #26
Thanked: 135 Times
This is possibly because of EGR valve remaining open all the time. Check the electrical connection for actuation of the valve, in worst case replacing the EGR valve should solve your problem.
AMG_ang is offline   (1) Thanks
Old 21st December 2013, 17:18   #27
Thanked: 3,011 Times
The concept behind a compression engine is of total loss, the intake of clean air, compressed with diesel fuel, leading to an explosion and the waste gases being scavenged out of the exhaust.
Adding devices like the EGR is a compromise, where in one tries to clean up the tail pipe gases by re-burning the same gas in the combustion chamber. At the best, it will reduce power and decrease mileage, every time fresh diesel combines with exhaust air in the chambers.
Over time the soot/carbon from the exhaust gases will coat the interiors of the cylinders, the EGR valve and lead to a 'sticky' valve condition, with the valve being stuck in either open/closed condition.
If the valve is stuck close, then no issues with the power or mileage, but the ECU understands an error code and throws up amber/yellow light on the dash. If the valve is stuck in the open position, then the car struggles to make any power (dirty gases are going in continuously into the cylinders) and average drops.
The general idea behind the EGR is, to have a cheap way to burn the NO2 gases from the tailpipe, which are a byproduct of diesel combustion.
apachelongbow is offline   (3) Thanks
Old 16th February 2014, 22:28   #28
Thanked: 1,007 Times
do you need to clean the EGR valve, just as part of long term maintenance ?
does the cleaning job affect the fuel economy, probably increase ?
pcpranav is offline
Old 18th February 2014, 03:15   #29
Thanked: 21,450 Times
Yes it is good to clean the EGR as per manufacturer interval as a choked valve can send faulty information to the ECU and play around effecting the FE.
Worst is there could be emission issue to add the exhaust gases are escaping out fully but gad the EGR be working as it should lesser pollution and slightly more efficiency.
Anurag.
a4anurag is offline
Old 18th February 2014, 12:20   #30
DerAlte's Avatar
Thanked: 2,920 Times
... choked valve can send faulty information to the ECU and play around effecting the FE. ...
In EGR valves that have a position sensor (some old ones don't), the sensor will faithfully send signal that the EGR valve is stuck. That is information about fault, not 'faulty information'! If the valve passageways are choked there is no way to know, other than with a NOx sensor.
Also, EGR doesn't affect FE - it is exclusively for NOx reduction. If EGR is not working, you might get better FE (don't try it though).
DerAlte is offline   (2) Thanks
