Re: Problem with brand-new BMW X3 Quote:
Originally Posted by aman-bh October 2019: Purchased my brand new BMW X3 30i,after delivery noticed that the wheel alignment and balancing was a little off, however as the car is required on a daily basis without fail and BMW requires to keep the car for 2 days for that, I chose to get this fixed at the first service.
October 2020: Come the first service at Bird, and I conveyed this issue and was charged 12,500rs excluding labour for the same which I hesitantly gave at that point because I needed to get it rectified. |
I won't say that it's impossible but very chances of getting an unaligned car from BMW is close to Nil. You should have taken the car back immediately. Can you mention the mileage you have done in 12 months, any misaligned car will simply chew up the tires. It's quite possible that you think that alignment is off, this happens mostly due to our roads (slope for water) And for balancing, did you steering vibrated? and at what speeds?
BMW has 2 separate charges for wheel alignment inspection and second for correction. Though, dealerships will insist that once they put the car on the machine, they will have to do changes. Always insist on Inspection first and if the readings are close to standard, there is no need for adjustment. It costs around 2000 -2500 for each job (total 4500). For some reasons, BMW in India charges costs of weights extra and sometimes if there is a bend on the rim or they don't remove old weights, these can add a lot to the bill. Can you still post a copy of invoice here? Quote:
Spoke to the service advisor and once again was told that the sensor might have an issue and they'll have to keep the car at bird for 2 days and also that I might have to pay for alignment again.
| Quote:
Will I have pay again to get the balancing done
Tell them to inspect the car alignment again if you are not satisfied. Regarding turnaround time, they can be sometimes busy so best is to reach early morning and drop the car yourself. I have got many jobs done on the same day. For balancing, go to the Pirelli centre. They have road force hunter machines. I will share the address later in the day as they moved from earlier address. Quote:
Will be visiting Bird this week, any suggestions would be appreciated.
Ask for Mr. Shariq, he is a senior guy and will sort your issues. I will also speak to him and see how can they help you. Quote:
Originally Posted by quattroa4 RFTs have stiff side walls and hence there is no flex in tyres , so they are not compensated for Camber in cars that are using them .
There is no arrangement for camber setting as well as toe as they are considered to be one solid piece . |
That's not correct. RFT's have nothing to do with Car suspension, if that would have been the case, none of the cars with regular tyres would have been on the road.
However, it's also a fact that the built quality/ type of material/ components used in these cars is topnotch and you hardly need to get an alignment done. I mostly get the inspection at yearly service but hardly any time adjustments were required. Quote:
Originally Posted by skhattar I looked at the wiper arms and - lo and behold - they didnt belong to my car. They were very old and clearly they have been swapped.
Then I got an email from them that " We shall replace your wiper arms with a brand new ones as a goodwill gesture". Yeah right...
I got the part replaced with a new one FOC. |
The only reasons, I can think is that someone tried swapping to remove/ check the fault and then conveniently letting interchanged ones in respective cars
Not a correct way to investigate but this happens all the time at many dealerships across the brands, interchanging parts with another car, demo mostly and trying to replicate or find the problem. My brand new endeavour had a check engine light and the workshop guys interchanged 3 sensors from a demo unit, both cars worked fine, and no this had nothing to do with loose connections as we tried putting the original sensors back to mine and the same fault will come up in my car but not on the demo
