Old 15th November 2022, 20:19   #76
Thanked: 2,063 Times
Re: Volkswagen Polo: 4 ABS sensor failures in 2 years
Originally Posted by amitmk View Post
Post this the car appears to have become a bit heavier (sluggish) while driving.
Brake pads of front wheels and disc skimming was also done when sensors were changed.
Why are you suspecting the ABS sensors but not the changed brake pads and skimmed rotor? Check if the clearance between the new brake pads and the rotor is proper. I suspect the brake pads are not having enough clearance from the rotor which should be the reason why your car feel sluggish.
pavi is offline
Old 18th November 2022, 17:41   #77
rkv_2401's Avatar
Thanked: 544 Times
I replaced all 4 sensors out of an abundance of caution after 2 failed in short succession 2 years ago. Fast forward to last week and one more has failed, got that replaced under warranty but then two days after the car came back yet another one has failed. I guess I take the lead in this thread with 4 failures and 6 (or maybe 8? Let's see) replacements in 2 years.
rkv_2401 is offline   (1) Thanks
