Old 22nd May 2007, 09:48   #226
rdkarthik's Avatar
Thanked: 13 Times
Originally Posted by veyron1 View Post
Ok. Here goes. Speed/density metering or mapping is usually dependent on engine speed, air density and MAP.
Alpha-n is the advanced version for mapping which can take in more radical cam profiles because it reads from the engine RPM and throttle body positioning only, bypassing the MAP.
Alpha-N is not an advanced version for mapping. Its just an alternative. It works great on wild cam profiles because these cams produce a lot of pressure fluctuations in the intake manifold when they are working at RPMs other than designed for, confusing the speed-density system.
Now, both systems/routings are prone to vacuum errors/stats.
What errors are you talking about? Is it computed quantity of air in the system?
Alpha-N does not depend on vacuum anyway...
The Escorts had TBIs. How exactly did the alpha-n system "improve" the combustion characterisitics? AFAIK, MPFI's have much more precise fuel metering, correct?
right.. MPFIs are far better than TBI for precision and metering.. MPFIs can be Alpha-N too.
wrt escorts, when compared to a carb system, alpha-N TBI is definetly an improvement, but not wrt mpfi and/or speed-speed density ssytem for a stock car.
Ok. Now for details. Let's have in detail the effects on cam profiles for alpha-n (since that's what's used for racing applications- we know that poppet and stem height are in direct relation to lift; so we'll go into that later),and ignition timing (both ignitor mapping and delco alteration-for the Escort). And how exactly do both of them alter IPW at WOT (assuming WOT is at 100%, both systems are giving 100% fuel flow)....
i thought the escort had a distributorless setup...
Simply put, let's have in detail the differences in ACTUAL practical applications, and how-to's...
1. With Alpha-N its very difficult to pass emission standards, even at OEM levels - E2,E3,E4,etc, as compared to speed-density or maf. Thats why we dont see them on street cars (execpt in limp home mode with a screwed map sensor system)
2. Alpha-N is prefered (actually a must) for individual throttle body and/or wild cam profile applications.
3. MAP or MAF is a must for turbo/supercharger applications
waiting for the guys to chip in.......
rdkarthik is offline
Old 22nd May 2007, 10:22   #227
chetanhanda's Avatar
Thanked: 49 Times
speed density uses 3 things - vacum readings from MAP , RPM and AFR IPW is then looked up for values of x,y and z..
didnt understand where you got air density and MAP as 2 diff params...?
Alpha-n uses TPS and RPM and provides the corresponding IPW
Alpha-n is the advanced version for mapping which can take in more radical cam profiles because it reads from the engine RPM and throttle body positioning only.
I wouldn't call Alpha-n as the advanced version for mapping..
it simply makes the mapping more simple and less complex, I would call it a more crude way of metering my fuel.. e.g it doesn't bother abt IAT,isnt very sensitive to slight TP and pretty much useless for forced induction applications as I need the ECU to calulate precise boost.. coz TP wouldnt directly be proportional to the air being sucked in
Usage - [1]Only if the radical cam profile is causing pulses in the intake to such an extent that the MAP is unable to provide an accurate resolution due to fluctuations
[2] OR if I am using ITB ... getting MAP to work will be a tough one with 1 map sensor per runner
bypassing the MAP.
Only if you go in for a customised hybrid system using both alpha-n and MAP.. Atleast I dont know of any application using both ..Ive heard MAP or MAF or alpha-n controlled sytems but not combination of all 3..
Ford Escort had a primitive 50 BHP engine, it used alpha-n becoz it was simpler not becoz the cam was so lumpy that a MAP would have failed to get a steady reading.. due to changes in vacum on every intake cycle..
Also as you have mentioned it had a TBI ..so Im guessing the alpha-n would have been easier to implement....
CAM profile wont directly affect the choice of alpha-n over MAP.
If we dont have constraint on the length of the intake runners we can even out the intake pulses to an extent... and even use crazy overlapping cams and use MAP, without having to move to alpha-n
And I feel ITB would also be a bigger reason to move to alpha-n.
are u talking in context of valves which dont use springs ? something like used on ducatti .. desmodromic? they dont use springs coz they dont cause valve float...
(This is OT are u from the biker background ..becoz AFAIK we use stiffer valve springs if we are planning to rev higher than stock spec..)
IPW at WOT for MAP is not altered.. the ECU simply goes into open loop at WOT for a MAP.. I dont think the ECU alters the IPW when it goes into WOT.. it simply loads a diff MAP.. only under part throttle it will try to provide diff IPW's
regarding alpha-n - I dont know coz I havent seen any fuel/ignition maps of cars running alpha-n sytems..
chetanhanda is offline
Old 22nd May 2007, 10:32   #228
Thanked: 49 Times
.. we can minimise the pulses to a certain extent only by tuning the length of the intake runner but again we have restrictions as to how much we can compensate by doing this ... alpha-n is the next best soln
yes dude and these alpha-n systems dont consider target AFR at all like speed density systems ..base maps simply say x rpm and y TP = IPW in simple words..
Old 22nd May 2007, 11:20   #229
Ford Rocam's Avatar
Thanked: 23 Times
Alpha-n As the name implies is alternative method for metering fuel by using throttle position sensor in the column index in a fuel table thus name "Alpha-n" after throttle angle = (alpha) & engine speed = (n).
why its preferred to use for tuning with I.T.B? cause Map sensor (or speed density) will never be able to provide air pressure signal with respect to actual air entering the engine because of specific characteristics of I.T.B hence if using Map for I.T.B it will not be able to value fuel correctly & it will be very sensitive to small changes & can become very lean with change in elevation or ambient air pressure.
just my 2 cents...
Ford Rocam is offline
Old 22nd May 2007, 11:53   #230
Deepz's Avatar
Originally Posted by mclaren1885 View Post
Get headers calculated accordingly. Get a cam that gives you the kick in this range.
Hi McLaren,thanks for the info..If any furthur suggestions to do the same please let me know..Thanks again..
Deepz is offline
Old 22nd May 2007, 18:18   #231
veyron1's Avatar
Thanked: 54 Times
MAP is Hg. Pressure. Air density is read as temperature. IAT. Hence the mentioning as different parameters. But how is AFR IPW taken as one? IPW is computed from others for appropriate AFR, correct?
Alpha-N is not an advanced version for mapping. Its just an alternative.....
Ah. Ok. That clears a lot.
Originally Posted by Ford Rocam
Alpha-n As the name implies is alternative method for metering fuel by using...
Superb. Exact practical use explanation.
Right. But I'm still not quite sure we're on the same track here. By computed quantity, you mean the actual or residual values for intake at the ECM end for calculating IPW, correct?
Neat. So here's a doozie. What happens for TC/SC applications, where we have to monitor boost as well via MAF (if we try to use ITB as well, that is) ? ITB's and aplha-n mappings are great for N.A, but does it or can it actually make a marked improvement for boost applications?
Nope. No digital ignition/DDLi for the Fords. Camshaft run delco at right end of valve cover. Which was why I wondered about the alteration specifics.
No, I was talking about ordinary valves, not the desmosedici/desmodronic setup. But let's get into that after the mapping is a bit clearer. (LOL....I'm not from a biker background per se...I prefer cars as well...ever so slightly...)
Great stuff so far....things are getting much clearer...especially for learners like me....
veyron1 is offline
Old 22nd May 2007, 23:22   #232
rdkarthik's Avatar
Thanked: 13 Times
IPW is computed from a lot of parameters , including target AFR and feedback from existing AFR(for closed loop only).
To make it simple, speed = RPM, density = manifold pressure (as you said), but air temp, engine temp, altitude, AFR,VE,etc come in as correction factors..
I am lost too ... I was referring to errors you mentioned regarding vacuum..well, computed quantity is residual exhaust/overlapped charge + fresh charge with all corrections in place..
In cases of TC/SC with ITB, you will have to go map way. I am guessing it should be okay ( still wondering why you would want a boosted ITB ) as pressure pulses would be dampened due to common intake chamber....
Mapping with ITB, Alpha-N and TC/SC will be difficult (never precise) ,but should be able to get away with atleast for WOT..
i'm not sure abt this, but i vaguely remember playing with ignition on a 1.6 zetec escort (or was it astra??).. it was a 3 wire twin coil wasted spark system...let me chk on this..... most fords have DDI though....
We are all learning too .........
Old 23rd May 2007, 00:48   #233
vezj420's Avatar
Thanked: 23 Times
Karthik, Fords (even the ones here) use a 4-tower ignition coil. Not sure about the Escort though.
I have a slightly off-topic question for you (and sorry if u've already answered it before):
What do u (Race Dynamics) use to read the ECU Maps of the cars u work on?
vezj420 is offline
Old 23rd May 2007, 08:27   #234
rdkarthik's Avatar
Thanked: 13 Times
Well, on the fords its essentially twin coils bundled into a single package, that ends up looking like 4 tower ignition coil ...
We dont read any maps off the original ECUs at all.... We build all our maps ( and all its associated correction and setup parameters ) from scratch. ...
Old 28th May 2007, 00:58   #235
speed0mania's Avatar
Thanked: 7 Times
hey guys ! i have a doubt regarding how the 1/4 times for my car will be affected if i get a custom ffe with headers for low-mid range for my swift! i know this would shift the power band lower and not increase power in total, but apart from the launch rpm getting lower would it bring down the overall 1/4 mile time?
p.s. this is just a doubt that popped up! i know team bhp doesn't supprot illegal street racing in any way!
speed0mania is offline
Old 28th May 2007, 14:03   #236
veyron1's Avatar
Thanked: 54 Times
@speedomania; You'd get better 60-feet timings. Provided you have good traction. After that, it's all about the top end. Low/mid range mods are good for in city driving. Could actually give you better F.E, if driven properly.
veyron1 is offline
Old 29th May 2007, 18:35   #237
Thanked: 7 Times
thats what i want it for basically! better city daily driving! but i dont really want to miss out on the kick the swift gives @4.5k rpm ! (rare times i get to that) ! i know it can give me better FE but dont think ill be getting any with the type of revving ill be upto with a FFE!
now im confused bout what to get!
Old 3rd June 2007, 13:56   #238
streetsdisciple's Avatar
Learnt allot from reading this thread , good job everyone who helped to clear out the misconceptions about performance mods.
one question - what are Piggy Back Chips ?? how much do they cost ??
am asking this coz i read in someone`s garage here that it increased the output by 15-18 bhp.!
streetsdisciple is offline
Old 8th June 2007, 19:36   #239
vezj420's Avatar
Thanked: 23 Times
Karthik, that's what I meant!! I know u guys build the maps from scratch, buuut, don't u think it would be beneficial if u could read the map and THEN alter the values? (rather than trial & error from the start) I'm asking because I know a division in my company that uses these map scanners. Do u think they would help u?
SD, piggy back chips are chips/modules that latch onto your existing ECU (hence the name) to read and alter the existing maps for ignition, fuel timings, etc. The problem with them is, you have to get ones that are compatible with your car's ECU or are at least retunable, otherwise it's a big waste of money. Expect to pay between Rs. 20k and 40k for a basic to mid-range solution, in India as well as imported. Pete's Performance has a few in stock for a few cars here....
vezj420 is offline
Old 22nd June 2007, 19:25   #240
Deepz's Avatar
Someone once told me the following statement- "dude try this, put some naptholene(not sure about spelling) ball s near the air filter, your petrol will become high octane fuel". I told him not to mention this near a fuel station, the attendants will beat you for letting out their secret.
Deepz is offline
