Old 21st September 2020, 14:02   #61
Thanked: 477 Times
Re: Why are VAG diesel engines so noisy?
A thread I wholeheartedly resonate with. My 1.6 GT TDI is running a stage 2 tune with a downpipe. The downpipe adds more bass to the first crank but it quickly settles into a very clattery idle which is unmistakably the sound of a very agrarian diesel tractor. There is simply no sugarcoating this.
The only saving grace is that once on the move, the turbo whirrs and whines take over to a certain degree and post 3k RPM, it somehow miraculously sounds sporty and aggressive for a diesel.
The clutch of this car was hard and let vibrations through, even in stock form. With the delete of the catalytic converter, and having a rodent chew up bits of the under-bonnet damping and the Bilstein B6 suspension. NVH in my car is a lost cause.
It is not only its performance but even the NVH levels that have been turned up to eleven. A coal roller with stiff suspension and a peaky (read: exciting) power band, It's a glass of pure distilled pleasure for an enthusiast as far as I see it.
n:CorE is offline   (4) Thanks
Old 21st September 2020, 14:22   #62
ashis89's Avatar
Thanked: 12,148 Times
Going off-topic here, I found another car to be surprisingly noisy - Merc GLE 250d.
The first time, I saw a rather new Merc GLE 250d in the basement parking of a mall. Even though the parking was spacious, I could hear the clatter echo to be very sharp and annoying.
There's another GLE 250 which visits our apartment regularly. I have heard that car too at idle and it was loud. Never expected a Mercedes to be this noisy.
ashis89 is offline   (1) Thanks
Old 15th December 2020, 18:50   #63
tirumalavoleti's Avatar
Thanked: 221 Times
What should i write about. :-)
I owned both VAG diesel and Honda diesel. Cant drive neither with out an audio system.
Personally felt VAG diesel better than the Honda due to the cabin insulation inside. But outside noise, no clear worst
tirumalavoleti is offline
Old 23rd January 2021, 23:07   #64
Thanked: 191 Times
Own a Skoda Fabia and used to own Honda Amaze Diesel 1st Gen. The Honda was waaaaay noisier. I tried everything, final possible solution was to take off the dashboard and reinforce the insulation. Sold the car before that. It was an old faithful though.
In fact, noticed that engine oil matters. Switched to a better brand, and NVH for Fabia as came down.
BNG-motorhead is offline
Old 31st January 2021, 13:23   #65
maestro's Avatar
Thanked: 12 Times
Originally Posted by Shreyans_Jain View Post
My friend, you need to spend some time with a diesel City or Amaze. Honda’s 1.5 iDTEC takes the cake for being the single worst engine when it comes to NVH.
The VW engine sounds coarse in its own right, but at least it is rev happy and provides punchy performance and a wide torque curve.
The Hooda body is quite light. Increased NVH is also a reason due to the lower damping provided by less mass.
maestro is offline
Old 7th February 2021, 02:16   #66
Thanked: 191 Times
Then why not petrol? Its just an unrefined engine with cost cutting on dampening. iDtec is the first diesel engine got honda.
Old 7th February 2021, 06:26   #67
maestro's Avatar
Thanked: 12 Times
Firstly, the Diesel engines are built much stronger, therefore heavier to withstand the higher stresses in a compression ignition engine. These engines also run with much more NVH than petrol.
Secondly, modern diesels are all direct injected. These engines are noisier than the old ones with the pre-combustion chamber. But they developed more power, better throttle response and fuel efficiency, hence is preferred in modern vehicles.
Thirdly, a lighter body has less mass to dampen out the engine vibrations, so some NVH felt inside the cabin, even though there is adequate amount of vibration dampening on the engine mount and noise insulation. This is not the case outside the vehicle.
Contrary to what you state, mechanically, diesels are far more fuel efficient, run cooler with all the attendant benefits, run longer due to the sturdy construction. On the flip side, they have more NVH, and emissions are more difficult to control, especially the particulate matters and SOX depend on type of fuel used. They are usually lower in NOX.
maestro is offline   (1) Thanks
Old 7th February 2021, 17:55   #68
Thanked: 191 Times
Tech’s not the point. Point is insulation and using higher quality dampening material. Own both Honda diesel and VAG diesel. On the outside, similar noise. On the inside, VAG is much superior. Apart from engines, there is not much quality about the Honda.
Essentially, they swapped the petrol with diesel, kept the body quality same, listening Honda?
BNG-motorhead is offline   (1) Thanks
Old 15th February 2021, 09:52   #69
dicor's Avatar
Thanked: 1,363 Times
What I have noticed is all Germans and USAs and are noisy from day 1 and become tractor when they ages. I literally call my sister in laws Laura as TATA 407.
Japanese and Czech are smooth in initial days (Honda being an exception) and eventually they also become tractor... (Try to hear old Innova or Fortuner. They sound horrible)
I am yet to notice a loud Korean.
P.S. - This is purely for Diesels.
dicor is offline   (1) Thanks
