Old 21st July 2020, 10:33   #1
Thanked: 1,045 Times
FAQs about DPF (Diesel Particulate Filter)
Originally Posted by sv97 View Post
How long does the ad blue last in seltos and after how many kilometers it requires DPF regeneration?
Can the respective owners please reply.
sv97 is offline
Old 21st July 2020, 10:46   #2
Thanked: 343 Times
Re: Kia Seltos : Official Review
Seltos doesn't use adblue, just the DPF. Engines having 2L and above like Harrier are using adblue
jothishX is offline   (2) Thanks
Old 21st July 2020, 10:46   #3
Thanked: 21,450 Times
Not an owner but replying to the best of information that I know. Seltos uses a DPF to meet BS VI standards, no AdBlue is used. Larger displacement engines will need the AdBlue to be added.
Last edited by a4anurag : 21st July 2020 at 11:01. Reason: Corrected: Lean NOx trap > DPF
Old 21st July 2020, 10:46   #4
What happens in case the DPF gets clogged?
sv97 is offline
Old 21st July 2020, 10:49   #5
It throws a warning light on the instrument console. You regenerate the DPF by letting the car do it on its own or take the car on a highway and drive it at say 3,000 RPM for a short duration. The heat generated in the exhaust system will free the DPF and the warning light should go away.
a4anurag is offline   (3) Thanks
Old 21st July 2020, 10:51   #6
It throws a warning light on the instrument console. You either regenerate the DPF by letting the car do it on it's own or take the car on a highway and drive it at say 3,000 RPM for a short duration. The heat generated will free the DPF and the warning light should go away.
Sorry for posting so many questions but how does it happen on its own?
sv97 is offline   (1) Thanks
Old 21st July 2020, 10:58   #7
Bibendum90949's Avatar
Thanked: 7,456 Times
Please refer the link to my earlier post on the subject in this thread itself.
https://www.team-bhp.com/forum/offic...ml#post4771540 (Kia Seltos : Official Review)
Bibendum90949 is offline   (2) Thanks
Old 21st July 2020, 11:00   #8
Here's the information from the owner's manual:
Old 21st July 2020, 11:00   #9
AMG Power's Avatar
Thanked: 8,847 Times
There is no DPF when there is a LNT.
For those who have posted earlier, please note that Adblue is a proprietary name just like using Xerox instead of photostat - the right term is DEF or Diesel Exhaust Fluid.
LNT's can be regenerated when the warning light comes on by subjecting it to a fairly high speed run - it needs to heat up to remove the Sulphur deposits. Each regeneration reduces its life.
LNT's are not as effective as DPF's in removing pollutants and remains to be seen whether they will survive the increasingly stricter emission norms.
AMG Power is offline   (7) Thanks
Old 21st July 2020, 11:03   #10
Thank you sir for correcting me. Apologies for posting incorrect information. Corrected my original post.
DPF is preferred for engines with smaller displacement I presume.
Old 21st July 2020, 11:25   #11
AMG Power's Avatar
No issues.
DPF is required in larger displacement engines where the quantum of pollutants released is higher.
Old 21st July 2020, 11:28   #12
Reinhard's Avatar
Thanked: 18,117 Times
A possibly naive query from me then -
DPF = Diesel Particulate Filter. As the name suggests, its job is to block the "particulate matter" i.e. CARBON SOOT from getting launched into the air from the exhaust. (Which used to be the tell-tale sign black smoke of a diesel engine since decades in India.)
LNT = Lean NOx Trap. This is supposed to absorb the NOx (NO and NO2) from the exhaust fumes.
So how can LNT actually replace DPF altogether? Shouldn't the two work in tandem to achieve the final result of a cleaner exhaust?
No issues.
IIRC - the humble 1.5 TDCi from Ford needs a DPF even to be BSIV compliant.
Reinhard is offline
Old 21st July 2020, 11:37   #13
DPF = Diesel Particulate Filter. As the name suggests, its job is to block the "particulate matter" i.e. CARBON SOOT from getting launched into the air from the exhaust. (Which used to be the tell-tale sign of a diesel engine since decades in India.)
I would like to add SCR too to the discussion.
DPF - for smaller displacement engines like 1.3, 1.5 L etc.
SCR - for higher displacement generally > 2.0 L.
FAQs about DPF (Diesel Particulate Filter)-scrgraphicv3nocaption_website_opt.jpg
Sometimes SCR is coupled with DPF too to achieve even greater emission controls in heavy duty trucks etc. More on the links below.
http://www.hartridge.com/blog/3-diff...nd-scr-filters
https://www.dieselforum.org/about-cl...el/what-is-scr
Bibendum90949 is offline   (1) Thanks
Old 23rd July 2020, 14:27   #14
Thanked: 86,393 Times
Re: FAQs about DPF (Diesel Particulate Filter)
FAQs about DPF (Diesel Particulate Filter) - Posts moved to a new thread.
Aditya is offline   (1) Thanks
Old 23rd July 2020, 17:08   #15
AMG Power's Avatar
LNT is used in place of a SCR and not DPF as mentioned. However while SCR's need a reductant - Diesel exhaust fluid - that some folks call Adblue, the LNT does not need that. A few manufacturers use an LNT and a SCR.
The 1.5 TDCI uses a DPF only in the BSVI version launched this year. DPF is used in engines that are >1500.
