Re: CVT Transmission (Gear) Oil replacement for the Maruti Baleno CVT I have done it in Nexa bangalore - yelahanka
I ordered them all the required list which one of them had shared it in this blog, paid them a advance of 2500, material arrived after 30 days
Stood personally & had it replaced, I am a mechanical engineer & understand these stuff to a decent extent.
Unfortunately they did not have a proper funnel & measure while adding the new fluid. It is a good idea if we carry & measure & a funnel with us. It is also good to measure what is drained & then replace the same amount. Having lower or higher levels than the threshold can create fresh problems. Post changing it even though my car had run only 47k in 7 years has made a big difference and I am happy about it. Would prefer to do it once in next 3 years or 30k kms for sure, if the car is still with me.
If this was not a success I was already thinking of changing this vehicle, but now I do not see any reason. Hope this helps. Let me know if you need any other info
Contact service manager Nexa yelahanka - bangalore - Sunil 9513447916
Material list ordered - 6572-58MR0 STRAINER ASSY/ FILTER
24762-82KA0 GASKET, T/M OIL PAN
24823-54LS0 PLUG, DRAIN (OPT)
24824-54LS0 GASKET, DRAIN PLUG (OPT)
99000-22B63-046, CVT FLUID GREEN-2. Only 1 can will suffice
Total bill to expect - Rs.10000 inclusive labor of 1000
This is the premium we pay for using a automatic which is very convenient compared to manual |
