Old 20th February 2007, 14:21   #1
16v100bhp's Avatar
Thanked: 12 Times
Whats a Wet Nitrous?
Hi Guyz,
I was thinking of putting a nitrous kit onto the current setup of my Palio. Please keep in mind that i just have my exhaust and induction done up yet. Dont get shocked by the idea, I just wanted to get more info on this before i move in for the kill My tuner here told me that you can go in for a wet nitrous kit directly on to this setup... I've got some queries on this now..
1. What exactly does a wet nitrous kit contain and how does is it different from the normal ones?
2. How much would the power go upto when in nitrous mode?
2. Would it need any other addon, like FMU, turbo, performance cams/pistons or any other?
3. How much would it effect the wear and tear of the engine and what should i do extra as part of my regular maintance cycle?
16v100bhp is offline
Old 20th February 2007, 14:34   #2
theMAG's Avatar
Thanked: 1,821 Times
Wet NOS systems have fuel with them during injection into the throttle body. They're supposed to keep the petrol-air mixture lean by balancing out the extra O2 from the N02. Their disadvantage is bad backfiring.
theMAG is offline
Old 20th February 2007, 17:49   #3
mclaren1885's Avatar
Thanked: 46 Times
Infractions: 0/1 (10)
In dry systems you have only Nitrous being injected into the TB , however in case of wet nitrous kit you have both fuel and Nitrous being injected into the throttle body or the intake manifold depending on whether its a single shot or a multiport kit .. Advantages with the multiport kit is that each cylinder recieves a equal share of NOS and fuel and thus the power delivery is smoother and better .. Also the loss is less compared to the single shot ..
Things to keep in mind while at it :
1. Choose the right amount of NOS shot you want .. Too much and you will fry your internals ..
2. If you are going out and out for drag racing , then better get forged conrods , pistons to help you go higher on the shot ..
3. Also make sure that you dont increase your compression because that will again lead to engine trouble .. For eg on a baleno with stock compression one can go upto a safe 50-65 shot .. However on lowering the compression i know of cars running 100 shot at CR of 8.0:1 ..
4. Also firing of NOS continously loads the engine a lot , so ought to be used wisely ..
5. Against the normal scheme of things one will need colder range spark plugs and not the hot range ones ..
6. Bottle pressures should be maintained at about 900psi for optimum performance .. Any lower or higher might lead to improper power delivery ..
These are just a few points to remember , others will follow with the rest soon ..
But the feeling of being pulled ahead on firing NOS is something else .. Though its a cheaper and easier way to go faster , i would always prefer going TC .. Can be used almost daily , but setting it up is the problem ..
mclaren1885 is offline
Old 21st February 2007, 04:16   #4
101 RACING's Avatar
for your set up i`d say a single fogger dry 50-75 shot will do the job , any more would require a forged rebuild . depends what hp u chasing. rest as mclaren1885 said!
101 RACING is offline
Old 22nd February 2007, 12:43   #5
Rehaan's Avatar
Thanked: 36,067 Times
16v100bhp,
Please check this excellent thread out > http://www.team-bhp.com/forum/techni...ed-2-know.html
cya
R
Rehaan is offline
Old 22nd February 2007, 13:31   #6
16v100bhp's Avatar
Thanked: 12 Times
Thanks a lot guys. that was a lot of info... Wish me luck on my journey towards getting Wet...
Old 22nd February 2007, 16:27   #7
veyron1's Avatar
Thanked: 54 Times
Just a small pointer; it's actually the other way around. N20 disintegrates to nitrogen and oxygen thereby leaning the A/F, thus resulting in risk of detonation. Fuel is added so that the mixture gets richer, hence keeping the setup cool.
veyron1 is offline
Old 22nd February 2007, 18:17   #8
V-16's Avatar
Thanked: 960 Times
Originally Posted by 16v100bhp View Post
Whats a wet nitrous?
Our own Nitrous after hes been kissed by GR8Guzzler!!
Sorry could'nt resist this one!!
V-16 is offline
Old 7th May 2007, 04:52   #9
install in progress
Hi Guyz,
a dry kit injects only NOS [not recommended], a wet kit has two solenoids, one for the NOS and one for fuel so that the engine never suffers from inadequate fuel supply. then there is the direct port which has a feed for each cylinder[complicated to set up] hence the wet kit is the best option. the kit comes with various jets, the combination of fuel/NOS jet sets are avail for your HP requirments[ pls be conservative] so you could have a 25/50 or 75 HP shot jet set installed. you might need ign retart on engagement. my set up is in process on my GTX with a 25 HP shot of COLD FUSION kit and a MSD DIS-II kit. will update by this month end.
air870 is offline
