Originally Posted by shashank.nk
(Post 4652017)
Can you post a video ? My Swift (2011 make) also emits white smoke on cold start, however its usually for ~5 seconds or little more depending on the weather. Apparently, some DDIS engines emit white smoke, so I've learn't to live with it. I'm planning an injector test and cleaning if required, in November. I usually only see it in the mornings or at first start. |
Originally Posted by mithun
(Post 4651986)
Recently the car is emitting considerable white smoke for morning/first start of the day. |
Originally Posted by paragsachania
(Post 4652040)
White smoke, especially during start hints about unburnt diesel and this is very normal in cold weather conditions due to partial combustion till the engine heats up. Hence you can very well smell raw diesel for those few seconds when white smoke comes out of the exhaust and later the smell also vanishes along with the white smoke. What I did to overcome this was to use 2 cans of Liqui Moly fuel additive (not Purge) in 2 tankfulls, back to back and this white smoke has permanently vanished even during a cold start. May be the additive helped clean the fuel and injector lines to certain extent and they are functioning efficiently because even the idle note is calm and settled. |
(Post 4651986)
2013 Ritz ZDi clocked 70K KMS. The car is only serviced at Maruti A.S.S till date. Recently the car is emitting considerable white smoke for morning/first start of the day |
Originally Posted by vigsom
(Post 4652086)
I won't doubt the health of the engine at 70k kms. I hope you start the engine as soon as the heater symbol cuts off. For starters, why don't you just clean your air filter and see? |
Originally Posted by Jaggu
(Post 4652041)
Original reply - Is there oil consumption by the engine? If so how much is it? If the oil consumption is minor, best to ignore this. |
(Post 4652040)
(Post 4652103)
Is it safe? Any side affects? |
Basically there are 3 types of smoke emitted from a diesel engine: black, blue and white. Black smoke: Black smoke is the most common emitted from diesel engines and indicates incomplete combustion of the fuel. Black smoke causes can vary widely and include .. · Incorrect fuel injection timing · Dirty or worn fuel injectors · Over fuelling · Faulty turbocharger, or turbo lag · Faulty or dirty exhaust gas recycling (EGR) system · Incorrect valve clearance · Incorrect fuel to air ratio · Dirty or restricted air cleaner systems · Over loading the engine · Poor fuel quality · Cool operating temperatures · High altitude operation · Excessive carbon build-up in combustion and exhaust spaces Black smoke can occur across the entire operating range, but is usually worst under full power, or during the lag before the turbocharger boosts air supply to match the fuel usage such as in the early stages of acceleration and during gear changes. Moderate turbo lag smoke is acceptable; otherwise black smoke should be hardly visible in a correctly running engine. Blue smoke: Blue smoke is caused by engine lubricating oil burning. The oil can enter the combustion chamber from several sources including: · Worn valve guides, or seals · Cylinder &/or piston ring wear · Cylinder glaze · Piston ring sticking · Incorrect grade of oil .. too thin and getting past rings, or valves guides · Fuel dilution of the oil, making it too thin. Blue smoke is often evident at cold start, which can reflect reduced oil control due to carbon fouling deposits around the piston rings and/or cylinder glaze. Blue smoke should not be evident at any stage. An engine may burn oil without the evidence of blue smoke, because good compression burns oil quite cleanly, however, it is not acceptable for any new engine, or engine in good internal condition to burn large amounts of lubricating oil. White smoke: White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include: · Incorrect fuel injection timing · Defective fuel injectors · Low cylinder compression Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing. Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing. |
(Post 4652108)
If it wasn't, I would have posted here :). I don't use additives either. It's the first time I used only to clean the system. Earlier I had used Purge but the reason was different. My vehicle has done nearly 180,000 Km. |
Originally Posted by hserus
(Post 4652225)
Have you checked if your fuel filter (diesel filter) is due for a change yet? |
(Post 4652330)
Thanks. Is decarbonization required at this point? |
Originally Posted by New2Carz
(Post 4678195)
My daily ride is a 6 year old, 115K KMS driven Swift ZDi. I have noticed the white smoke problem on cold starts for the last year now and have also noticed a drop in engine pick up and peppiness. Last week I went for the DFSC from 3M . While the white smoke on cold starts still persist, there was a brief return of peppiness to the drive. Please suggest the next steps I can follow to get rid of the white smoke and get that peppiness in the drive that I loved about my swift. The engine oil change is due in another 1.5K, so I can get the necessary air/oil filters changed. Should I be looking for anything else? |
