Old 21st October 2019, 13:52   #16
clevermax's Avatar
Thanked: 2,897 Times
Re: Diesel engine - White smoke on morning starts
White smoke is unburned fuel. It could be due a number of reasons as listed down in the posts above, make sure that you have it properly diagnosed first. Have the A.S.S. scanned your ECU and checked for any errors logged?
clevermax is offline   (1) Thanks
Old 28th October 2019, 17:58   #17
Thanked: 268 Times
Update:
Used Liqui Moly Super Diesel Additive for 2 tankfuls and the smoke has reduced by 70%.
Do I need to use it once again?
Please advice on how can I fully eliminate the white smoke.
mithun is offline
Old 28th October 2019, 19:27   #18
hserus's Avatar
Thanked: 9,318 Times
Originally Posted by mithun View Post
Update:
Did you check and replace your fuel filter (aka diesel filter)?
hserus is offline
Old 28th October 2019, 19:28   #19
Thanked: 268 Times
Yes, it was replaced 12K KMS ago.
mithun is offline
Old 29th October 2019, 12:17   #20
Thanked: 110 Times
my 2008 swift vdi has run 2,20,000kms and for the last 3 to 4 months I have noticed white smoke on cold starts. The amount of white smoke varies . As usual the dealer(Sai Service, Ernakulam) did everything they know including EGR valve Cleaning, Changing oil etc. Finally came to the conclusion that the car needs injector replacement, that too all four. They quoted me around 75000/-inr for the whole exercise. Finally One of my friends suggested me a FNG and they adviced me to service the injectors before making replacement. Went to DIESEL INDIA and they found that the valves in one of the injectors was faulty, replaced those and touchwood...the smoke diasppeared.Its been more than two months now and the car is running fine till now.
Dilip
dilipkumar7278 is offline   (5) Thanks
Old 29th October 2019, 12:20   #21
Thanked: 268 Times
Originally Posted by dilipkumar7278 View Post
my 2008 swift vdi has run 2,20,000kms and for the last 3 to 4 months I have noticed white smoke on cold starts. The amount of white smoke varies . As usual the dealer(Sai Service, Ernakulam) did everything they know including EGR valve Cleaning, Changing oil etc. Finally came to the conclusion that the car needs injector replacement, that too all four. They quoted me around 75000/-inr for the whole exercise. Finally One of my friends suggested me a FNG and they adviced me to service the injectors before making replacement. Went to DIESEL INDIA and they founf that the valves in one of the injectors was faulty, replaced those and touchwood...the smoke diasppeared.Its been more than two months now and the car is running fine till now.
Dilip
Where is Diesel India? Location please.
How much did it cost?
mithun is offline
Old 29th October 2019, 12:24   #22
Thanked: 110 Times
I went to their kottayam branch...on the way to kumarakom...Cost me 7000/- INR by the way!!
dilipkumar7278 is offline   (1) Thanks
Old 29th October 2019, 12:27   #23
Thanked: 268 Times
Is this the one: https://goo.gl/maps/xHr8oBYkVnRwYuDu5
mithun is offline
Old 29th October 2019, 12:32   #24
Thanked: 110 Times
Yes...the same one... Contact person is Mr. Binu.Sening you the phone no. as PM
Old 28th November 2019, 21:56   #25
Thanked: 268 Times
Update:
Used 2 bottles of Liqui Moly Super Diesel Additive for 2 tankfuls and the smoke has reduced by 70%.
...or should I use any of these:
  1. https://www.amazon.in/Liqui-Moly-200...dp/B00CPL8OVE/
  2. https://www.amazon.in/Liqui-Moly-181...dp/B004X631O4/
  3. https://www.amazon.in/dp/B01N2NMQVY/
mithun is offline
