Old 12th August 2019, 00:02   #1
Thanked: 126 Times
Rattling noise from the exhaust of my BMW 328i
Hi everyone,
I needed some of you to weigh in on a a problem I'm facing with my BMW 328i. My car suddenly started making a rather loud rattling noise coming from the end of the exhaust pipe. The noise starts as soon as I start the engine, hot or cold, and continues while driving. It sounds exactly like this:
Thanks to the good folks of the world wide web, I figured out the problem. The noise is being caused by the exhaust flap. My car has an electronic flap within the exhaust pipe that opens and and closes depending whether the car is idling or being driven. As I understand, the actuator is broken, the flap has come loose and is making the rattling noise.
I went to the BMW service center and they identified the exact same problem. Their solution is to replace the entire exhaust set up which will cost me about 70k. Also, the part has to be imported from Germany and will take 3 weeks!!
I also went to a local workshop chain which goes by the name of GoMechanic (https://gomechanic.in/luxury-car-enquiry/bmw). They claim to have experienced mechanics, well verse with German cars. They also identified the same problem and said they could cut open the exhaust pipe, fix the flap and weld it back. This is likely to cost about 10-12k. I am very apprehensive about having the exhaust pipe cut open.
Additionally, reading on the internet, it seems there is a cheap and easy fix by installing a new spring/ fixing bow (https://parts.bmwnorthwest.com/p/BMW...307620323.html) and takes no more than 20 minutes.
I am afraid I am not receiving the most sound advice on this from the BMW workshop or this local workshop. I would really really appreciate if some of you could share some thoughts or suggest another mechanics/ workshop in South Delhi/ Gurgaon/ Noida where I can get some honest inputs.
Thanks a ton for reading and thank you in advance!
UDit
UD_328i is offline   (1) Thanks
Old 12th August 2019, 07:36   #2
vigsom's Avatar
Thanked: 29,823 Times
re: Rattling noise from the exhaust of my BMW 328i
The flap seems to just improve the residence time of the exhaust in the cat con for better conversion of CO; can't think of any other reason why this damper is given.
Anyways, if the bow spring connecting the actuator to the flap is broken, and thus the culprit, it can be replaced from outside; just need to lower the exhaust assembly from its mounting a bit to create access to replace the bow spring.
I suggest you take the car to a competent FNG in Mumbai and get this done.
Here are some pics of the actuator assembly; kindly reconfirm if the same applies to the 328i.
Some models have vacuum actuators while some are electronic.
Rattling noise from the exhaust of my BMW 328i-screenshot_20190812071858_1.jpg
Rattling noise from the exhaust of my BMW 328i-screenshot_20190812072635_1.jpg
vigsom is offline   (2) Thanks
Old 12th August 2019, 10:14   #3
HMV
HMV's Avatar
Thanked: 111 Times
EDIT: Sorry, It was only later that i realised that, it was just an illustrative video and not exact one!
Last edited by HMV : 12th August 2019 at 10:25. Reason: Deleting Unnecessary Quote
HMV is offline
Old 12th August 2019, 11:16   #4
Thanked: 126 Times
I believe that is the case. I am no expert on the issue but that is my understanding based on what I have read online and the feedback I have received from BMW as well as the local workshop.
I am not in Mumbai. I have relocated to New Delhi. I was hoping someone could recommend a trustworthy FNG in Delhi NCR where I could take care of this rattle without having to cut open the exhaust pipe.
Yes, you're right. The YouTube video demonstrating the sound is just for reference and is not a video of my actual car.
Last edited by moralfibre : 12th August 2019 at 12:10. Reason: Back to back posts.
UD_328i is offline
Old 12th August 2019, 11:50   #5
vigsom's Avatar
Please check this place out; it has been recommended in the directory of FNGs in Delhi.
There are other places in the directory too which you might want to evaluate.
https://www.team-bhp.com/forum/delhi...new-delhi.html (Friendly Neighborhood Garage (FNG) - Imtiaz & Ayub (New Delhi))
vigsom is offline   (1) Thanks
Old 12th August 2019, 12:49   #6
Thanked: 126 Times
Thanks a ton! This is very helpful. I had looked at the directory for Delhi NCR but somehow missed this. I will reach out to these guys tomorrow considering today is Eid. On that note, Eid Mubarak to everyone!
UD_328i is offline
