Re: 3rd-gen Honda City : Airbag warning light Quote:
Originally Posted by manishkapadia Hello All,
I just wanted to update here about this problem. My problem has been fixed. What i needed to do is replace the SRS Controller. For benefit of fellow members i am attaching pictures of replaced parts.
The issue was traced to the controller itself and not any of the sensors or Seat belts . When the OBD2 scan tool was connected, it would not communicate to the SRS system at all. This normally points to controller problem.
Now since my car is over 9 years old, going for authorised garage or Honda channel would be expensive. Insurance will have high deductions for car this old. The Srs controller itself is about 28.5 K MRP on the box.
Thankfully it is very easy to get genuine Honda parts at a fraction of the costs. Also had a bearing sound coming in after the flood which was traced to the Tensioner Bearing Assembly. This was changed and also was the alternator belt.
The work was done by my FNG guy who now works with Fiat Authorised garage in Kandivali Mumbai - RS Motors. Big shout to Ashish Bhatt over there. He has been taking care of our cars for a while now. The cars go wherever he goes. So if he switches job, i tend to send car where he is. All decent garages have now got good scan tools so it is easy to trace and fix a problem.
It cost me less than 15K to do everything, parts and labour including carpets removal and cleaning. |
Hi manishkapadia
I have faced the exact same issue with my Honda City 4th gen 2018 V model. It was parked in a colony in Delhi, and it probably rained heavily throughout the night. When I woke up in the morning and inspected the car, there was no water around the car but the area was wet. But inside the car, there was standing water on all the floor mats and even some of the seats also got wet. In my case, the cup holders did not get wet but most of the car was wet because of moisture being built up.
I took the car to a nearby garage to get the water out, and faced the same issue (SRS warning light). Took it to the Honda service centre and they also traced the problem back to the SRS Controller. Long story short, I'm getting it replaced through insurance (Honda had told me the cost would be 25k). For me, when I was driving the car initially after this wet episode, the Check Engine light also used to turn on intermittently and in one particular incidence, the Check Engine, SRS, ABS, Handbrake and Power Steering lights turned on for a while but then switched off again. Since then, only the SRS light used to turn on which has now been corrected as well. I informed Honda about the same but upon scanning, they only found an error for SRS. Wanted to check if you faced any other issues after getting this repair done?
Also regarding the wet carpets, did you get them replaced or just removing and drying did the trick and remove the odour completely? |
