Re: Case of a snapped timing belt in a Skoda Yeti Quote:
Originally Posted by dip27in If I drill down to the basic reason why it failed, probably there has been a design failure in this batch of yeti ( starting from 2009 to 2012) which was evident from the Tensioner bearing design on later model. The spring adjusting mechanism probably was placed too close without keeping in mind of the repeated heating and cooling factor of a cramped engine, especially in Indian scenario. |
As luck has this I joined this community and being my first post, I want to start by thanking you for sharing this. I have been keeping at used Yeti market for a few weeks now, as looking for a not large, bigger boot, comfortable , reliable engine and the added 4X4 for those long weekend trips to hill and beyond. Currently my hatch is good enough for daily needs.
This information is quite God sent it seems. It seems I should avoid the Yeti's from 2009 to 2012 or just ensure that i get a cheap deal so as to ensure I get the Belt and some basic maintenance done right after purchase. My main concern is health of engine, clutch and turbo. If need any guidance will connect with you. |
