Old 24th March 2015, 08:50   #1096
Thanked: 29 Times
re: OBD (On-board diagnostics) for Indian Cars
Yes i tried the same last week and it works perfectly though the refresh rate (along with hangups)was quite slow on the Bluetooth Module and much slower on the Wifi one.Cabled one was the best when connected to a laptop.Thanks for the inputs
Vinay Stanley is offline
Old 31st March 2015, 12:01   #1097
Thanked: 2,861 Times
Originally Posted by black12rr View Post
I am planning to buy the following OBD2 device for 06 civic. Any feedback on the device appreciated . Will it work ?
iCar OBDII ELM327 Bluetooth Car Diagnostic Tool - Black
http://www.dx.com/p/icar-obdii-elm32...0#.VPx3HI4pp60
or this one
2015 ELM327 Vgate Bluetooth iCar 3 OBDII ELM327 iCar3 Bluetooth Vgate OBD Diagnostic Interface
http://www.aliexpress.com/item/2015-...259795724.html
Why not buy it from a Bangalore supplier - I got my OBD2 device from dev_tech_blore on ebay. Mine works great. I dont know Devangs handle here on TBHP, but he seems a knowledgeable techie. Highly recommended (by me).
mvadg is offline   (1) Thanks
Old 31st March 2015, 14:12   #1098
black12rr's Avatar
Thanked: 349 Times
He has listed it with price range from 1800 to 2800 rs on ebay.
Ordered 2 ( one for a friend) of 2015 ELM327 Vgate Bluetooth iCar 3 from Aliexpress for 13.37 $ each. Waiting for it to arrive .
BTW which once did buy and what app are you for which car ? . Feedback please.
black12rr is offline
Old 31st March 2015, 14:27   #1099
devrajman's Avatar
Thanked: 119 Times
Thanks for the appreciation!
yes, the one with white box are priced higher.
devrajman is offline
Old 31st March 2015, 16:13   #1100
I got the "Premium ELM27 Bluetooth..." for my A-Star AT. Works with Torque, CarGauge and others.
I tried Fun2Drive from Bosch but it failed to show any data, even though it connected. I sent them feedback and I am hoping they will come up with a fix. Since they list "Indian" makes in the app, this app may turn out to be the best for us with all the extended information that is not shown for localized ECUs /Cars. I am hoping to see the ATF temperature on this app someday.
mvadg is offline
Old 31st March 2015, 18:26   #1101
Deepak K Gupta's Avatar
Thanked: 24 Times
Guys there are several models available from dev_tech_blore.
1)PREMIUM Android Torque ELM327 v2.1 ELM 327 Bluetooth OBDII OBD-II OBD2 Reader
2)Latest ELM327 USB ECU OBDII OBD2 EOBD CAN BUS Car Reader Scanner (not bluetooth)
3)Torque SuperMini ELM 327 v2.1 Bluetooth EOBD CAN-BUS OBD CAR Reader Scanner (Team BHP Listed)
4)Android Torque SuperMini ELM327 ECU Bluetooth OBDII CAR OBD2 Reader SCANNER v2.1 (Team BHP Listed)
I want to use one with my Ford Classic Petrol 2014 and VW Vento Petrol 2011.
Can anyone with prior experience with any of these help me make a decision.
Deepak K Gupta is offline
Old 31st March 2015, 18:59   #1102
devrajman's Avatar
Thanked: 119 Times
All of these work with both of your cars. However supermini has fitting issue with VENTO AFAIK so avoid that one.
Old 31st March 2015, 19:35   #1103
Thanked: 24 Times
So Se.No. 3 & 4 are both super mini and I need to avoid. Choice lies with Se. No. 1 & 2. Does the cable version have any advantage over the bluetooth or vice versa. I would suppose the bluetooth version would be the first choice for most.
Old 31st March 2015, 20:39   #1104
Thanked: 21,450 Times
I'd suggest you to go for the Bluetooth version for your car as it is reliable and doesn't drain the battery even when plugged full-time.
a4anurag is offline
Old 31st March 2015, 20:55   #1105
devrajman's Avatar
Thanked: 119 Times
There is VGate ELM327 also. Which is similar to 1) in function. Both will work without issue.
Old 3rd April 2015, 18:56   #1106
Hi Anurag
While going through this thread I had read your post regarding the ELM 327 working on the fortuner,
http://www.team-bhp.com/forum/techni...ml#post3431588
Could you please confirm this? From all reports on the internet, the Fortuner has an M-OBD port and is not OBD2 compatible.
Bopanna
kodava is offline
Old 19th April 2015, 21:44   #1107
rkg
Thanked: 599 Times
Which OBD II scanner and software will suit Tata ARIA 148hp version?
rkg is offline
Old 20th April 2015, 11:07   #1108
Thanked: 597 Times
All OBD II scanners will work fine with Tata Aria. I will recommend buy of VGate make, they are good and reliable compared to cheapo blue one.
Vgate ICAR 2 ARM Based on Amazon India
Vgate ICAR 1 on Amazon India
There are plenty options available to you on ebay as well as amazon.
sushantr5 is offline   (1) Thanks
Old 27th April 2015, 15:40   #1109
Thanked: 597 Times
Vgate ICAR3 is also available on Amazon India. Just saw that. Here is the link Vgate ICAR 3
Old 25th May 2015, 16:45   #1110
nijelj's Avatar
Thanked: 414 Times
Hi Guys, Can someone with a Wifi enabled OBD scanner,in Bangalore, let me know if I can check out to see if it works on my laptop. Please PM me your contact, I'll get in touch with you. Thanks!
nijelj is offline
