Old 5th September 2011, 18:22   #376
Savin_Shetty's Avatar
re: OBD (On-board diagnostics) for Indian Cars
[quote=Absar;544167]Hey Sss, I found the OBD connector in Santro. Thanks dilipkumar7278. The OBD connector is in the same place as in the accent, right under the steering column. I've added pictures for the location in the Santro.
The top of the picture shows the OBD port.
This is the OBD port..
Unfortunately It doesn't connect. It keeps on connecting even after a long time. This is on a Santro Xing btw.
...Can any one share picture/s for City Vtec 2000 OHV
Savin_Shetty is offline
Old 5th September 2011, 20:45   #377
anoop.mathew's Avatar
Thanked: 31 Times
The following cars are compatible with Scangauge (see the Scangauge thread) and should be compatible with other OBD scanners as well
1) Maruti Ritz (both petrol and diesel versions)
2) Maruti Swift (petrol, K12 version)
3) Maruti SX4 Diesel (not tested, but company claims that it is OBD2 compliant)
4) New Maruti Swift (not tested, but likely)
In the US, all cars after 1996 are compatible, but in India, other than the Maruti cars mentioned above, it is mostly the American cars (Ford, GM) that are compatible.
For Hyundai, the Santro is not, but the other current models are compatible.
There is not much data available on whether Tata cars are compatible or not.
Honda cars are also compatible, except for OHC/OHC Vtec.
Last edited by anoop.mathew : 5th September 2011 at 20:47. Reason: Added exception for OHC
anoop.mathew is offline   (1) Thanks
Old 5th September 2011, 21:10   #378
jealousdiamond's Avatar
Thanked: 107 Times
TATA cars too are very well OBD II compatible . I have tested the ELM 327 bluetooth on my Indica Petrol (Xeta) and My Safari and both reads and displays real time data .
The Indica shows a total of 26 sensors fucntional , however the Safari displays 19 of them only on the same software .
Hope this helps !!
jealousdiamond is offline   (2) Thanks
Old 6th September 2011, 19:25   #379
Thanked: 77 Times
Are you using a Bluetooth based elm or USB one??
Has anyone used a wifi based one and got any output??? Or anything for that matter with an iPad, iPod or iPhone?? These iOS devices support only wifi based ones.
scuderiaferrari is offline
Old 7th September 2011, 13:05   #380
Thanked: 584 Times
Originally Posted by zmint View Post
Hello everybody,
I got Tata Manza Bharat III. - Feb. 2011
I have also acquired a V1.5 ELM327 OBD2 OBDII CAN-BUS Diagnostic Scanner USB
but I am unable to connect to my vehicles ECU.
The software I tried are Scantool.net, Diginoto 4.03, ProScan 5.9, & Scanmaster.
The Scanmaster ELM shows only the battery level, with the following output :
Help me connecting successfully.
Hi Zmint,
Are you able to read OBD Signals from Manza? I am also planning to purchase OBD Bluetooth connector for my Vista QJD. But it seems Fiat Multijet is not having standard OBD protocol.
sushantr5 is offline
Old 7th September 2011, 17:08   #381
chetanhanda's Avatar
Thanked: 49 Times
Good summary, just to add ..
Maruti 800 12 valve has a connector which matches perfectly with the OBd2 adaptor but it does not read anything.
chetanhanda is offline   (1) Thanks
Old 8th September 2011, 12:17   #382
Thanked: 31 Times
Yes, many cars, such as the Santro Xing, Swift 1.3, Swift D (old), have a connector which resembles the OBD2 connector, but they use proprietary protocols, so the standard OBD2 scanners either don't work or have limited functionality when connected to these cars.
Unfortunately, the only way you can find out compatibility is by actually testing it. If your car is not in the list, please be aware that it may not be compatible. If anyone finds other cars which are compatible/incompatible, please add to the list so others benefit from it.
Scangauge/Ultragauge are devices in their own right, which connect to the OBD2 port via an OBD2 cable. There is no bluetooth, USB or WiFi involved.
Check out the Scangauge thread for more info.
Note from the Team-BHP Support: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the same thread.
Last edited by Technocrat : 7th September 2012 at 22:55. Reason: Please read the note in your post, thanks
Old 16th September 2011, 04:23   #383
Thanked: 396 Times
Just received the ELM327 1.5a USB wired module.
It works perfectly on my Optra Magnum TCDI.
I have used it with Hyperterminal and scanner tools like ScanMaster, ScanXL, EOBDII. All are showing great results!
keyur is offline
Old 16th September 2011, 08:05   #384
govigov's Avatar
Thanked: 1,097 Times
^^^ which site and how much?
govigov is offline
Old 16th September 2011, 13:41   #385
Thanked: 396 Times
I got it shipped from a friend in HongKong (cost me 50$). But a similar item is available here as well - free shipping!
keyur is offline   (1) Thanks
Old 16th September 2011, 15:13   #386
govigov's Avatar
^^^ thank you. deal extreme seems to take ages for shipping.
let me try to order one in any case.
govigov is offline
Old 16th September 2011, 15:38   #387
mayankk's Avatar
Thanked: 8,287 Times
so true.
but its so nice.
You order some inane things every 2nd-3rd day.
then it takes sooooooooooo long, that you forget about it.
and one day, when you come, there's a nice little package to surprise you!!
PS:lately, ive started receiving stuff in 15-20 days.
mayankk is offline
Old 16th September 2011, 23:09   #388
Thanked: 396 Times
Guys, have just started this thread. Please put in your car's OBD details in the thread
keyur is offline
Old 27th September 2011, 08:06   #389
Thanked: 34 Times
Originally Posted by sushantr5 View Post
Hi Zmint,
Hello everybody,
I researched and figured that Tata uses SAMTEC HS+ device to connect their ECU for Vista-Manza and Fiat cars to system and it has capability to read and reprogram the ECU and they have a software for same. Have you got any success with Scanmaster ELM?
tajender is offline
Old 20th October 2011, 12:03   #390
Thanked: 9,196 Times
The Bluetooth device connected flawlessly to the Petrol Ritz and A-Star AT. It even detected an ECU and the transmission control unit for the A-Star AT.
Which Bluetooth OBD scanner did you use? Any links? The one i have (ebay elm 327 clone), doesn't work with AStar MT. However it works with i10 1.2 MT.
What all reading did you get from AStar?
Sankar is offline
