Old 9th August 2011, 21:22   #361
re: OBD (On-board diagnostics) for Indian Cars
Will the ELM 327 OBD work in Honda City ZX. Has one tried it on the same car before..
Sahil M is offline
Old 11th August 2011, 15:21   #362
Behemoth's Avatar
Thanked: 5,903 Times
Hi Everyone,
Does anyone have any experience on Lemmiwinks ECU tuning?
It is essentially a very simple software (freeware) which allows you to tweak a lot of the engine settings. I am attaching a brief PDF from a guy called EdyJun (he used to be a pro with this, but seems to have disappeared recently).
The software can be used on most OBD2 compliant cars. You can easily find the software on the net (it was developed as a freeware by independent freelancers).
Need some help from the pros here and guidance from Auto R&D engineers on the forum who can explain what each of the parameters will do and what is the safe range in which they can be adjusted.
(Disclaimer: Please experiment at your own risk and don't try anything which you don't know.)
Behemoth is offline   (1) Thanks
Old 11th August 2011, 15:36   #363
JayD's Avatar
Thanked: 2,571 Times
Yes. I have tried it, on the NHC (Pre ZX)
JayD is online now
Old 11th August 2011, 17:10   #364
would want to try it now
Sahil M is offline
Old 24th August 2011, 19:17   #365
Hello everybody,
I got Tata Manza Bharat III. - Feb. 2011
I have also acquired a V1.5 ELM327 OBD2 OBDII CAN-BUS Diagnostic Scanner USB
but I am unable to connect to my vehicles ECU.
The software I tried are Scantool.net, Diginoto 4.03, ProScan 5.9, & Scanmaster.
The Scanmaster ELM shows only the battery level, with the following output :
Name:  tata manza.png
Help me connecting successfully.
zmint is offline
Old 25th August 2011, 20:53   #366
bejoy's Avatar
Thanked: 1,476 Times
Originally Posted by zmint View Post
Hello everybody,
Please post the picture of the OBD connector(with contacts visible) on the car. A picture of the ECU also would be great. Also confirm if you have Diesel or Petrol variant.
bejoy is offline   (1) Thanks
Old 26th August 2011, 19:09   #367
Thanks for the helping hand.
Here is the snap. If you zoom-in, the connectors are marked 1 to 16 starting bottom right. I think the actual metal contacts in the connectors are number 4, 5 & 7.
My manza is diesel variant & here is the ECU.
zmint is offline
Old 29th August 2011, 17:08   #368
contact 16 is also in the connector.
zmint is offline
Old 30th August 2011, 19:29   #369
bejoy's Avatar
I do not see a reason why the ELM327 is not able to detect the ECU.
I suggest you try with FiatECUScan software. 1.3 JTD is supported in the new version and it supports ELM devices.
bejoy is offline
Old 1st September 2011, 15:15   #370
dear bejoy i did every possible thing as suggested by you but with no success. thanks
zmint is offline
Old 2nd September 2011, 16:52   #371
Thanked: 111 Times
We tried with every other petrol fiat cars it worked like a charm but not on diesel fiat's. Dont know why
Vijay
vijaycool is offline
Old 3rd September 2011, 19:06   #372
Thanked: 77 Times
Re: Made it work on Palio
Originally Posted by DRC View Post
Finally, after 2 weeks of sniffing every byte going through serial port and a lot of help at the Fiat forum, I made ELM327 work on my Fiat petra with my own software. I am able to read error codes, Fiat drawing numbes and most live parameters..
Yet I have not been able to make it work on my wife's Swift. Let you all know when I meet success!
I bought a PLX Kiwi WiFi ELM327 Wifi device to connect the A-Star and Ritz Petrol ECU to my iPad. However, it does not give out any readings. Neither did it when I connected this to a Mac / Win machine. With an ELM 327 Bluetooth device, it connected and provided proper outputs.
can you please share some light on how you went about creating your software?
scuderiaferrari is offline
Old 5th September 2011, 13:44   #373
DRC
DRC's Avatar
Thanked: 66 Times
@Scudariaferrari
I am not sure it will help you, but I have not been successful connecting to any Maruti cars so far.
For Fiat, I used a serial port script to send and receive data. TeratermPro could be a good one to start with.
Anything worked on Swift 1.3? Please do let me know. would be great help
DRC is offline
Old 5th September 2011, 16:13   #374
coolaks7's Avatar
Thanked: 7 Times
Did ELM 327 worked on Ritz Petrol??
[quote=scuderiaferrari;2491964]With an ELM 327 Bluetooth device, it connected and provided proper outputs.
quote]
Hi scuderiaferrari,
Did the bluetooth ELM 327 bluetooth device worked on a Ritz petrol?? I am planning to buy the device from a long time but was not sure about it's compatibility with Ritz Petrol...
coolaks7 is offline
Old 5th September 2011, 17:53   #375
Thanked: 77 Times
[quote=coolaks7;2493906]
quote]
Hi scuderiaferrari,
The Bluetooth one did connect to the Petrol Ritz and even gave out readings on instantaneous fuel consumption on my Mac (used an app called movi demo). But the PLX Kiwi Wifi did not. It just gave me the voltage when I manually selected the protocol.
@Scudariaferrari
The Bluetooth device connected flawlessly to the Petrol Ritz and A-Star AT. It even detected an ECU and the transmission control unit for the A-Star AT.
Have not tried anything on the diesel yet.
My PLX Kiwi Wifi did not even connect to a Ford Fiesta diesel :(.
Not sure if it is a problem with the unit or if it is because the Indian ECUs use a different protocol.
If almost all these card are using OBD2, whit is it mentioned that SX4 is the first car which is OBD 2 certified in India? Has anyone tried any of these on the SX 4 diesel???
