Old 3rd January 2019, 04:27   #1
Leoshashi's Avatar
Thanked: 43,419 Times
Re: The 2018 next-gen Maruti Ertiga, now launched at Rs 7.44 lakhs
Originally Posted by PYSO View Post
The Body panels of new ertiga are definitely thicker than the old one - they don't flex as easily as the Body panels of the old one.
Originally Posted by cyberwhizs View Post
I concur with @pyso on the body panels part, while at the showroom , i tried to press it subtly on the fender and then the front door, it did not yield like i had expected it to.
Originally Posted by keshav1426 View Post
Was very happy to read your post regarding the body panels . The old Ertiga was more or less ok but it did dent easily. At that time , it was made much better than the Swift and desire. Now hearing that the new Ertiga felt stronger is definitely a plus point. More over , it will give the Maruti bashers something to ponder upon. Thanks for the information
Guys, concluding about body sheet metal thickness by testing the flex can be very misleading.
Today Auto Manufacturers are extensively using Structural patches to control excessive flexing of thinner sheet metal. The Marutis which we consider as well built, like the Ritz, SX4, S Cross etc all have such patches on the inside of panels.
Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal-20190103_042528.jpg
Hence it might be possible that the metal is still thin, but it won't flex due to such patches.
More details here:
Blog link: http://henkeladhesivesna.com/blog/ve...tural-patches/
Shashi
Last edited by GTO : 18th January 2019 at 10:37. Reason: Copying post to new thread :)
Leoshashi is offline   (39) Thanks
Old 18th January 2019, 10:37   #2
Thanked: 321,355 Times
Re: Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal
Thanks for sharing, Leoshashi! Learn something new everyday. Am copying your post to a new thread.
GTO is offline   (9) Thanks
Old 18th January 2019, 10:51   #3
saket77's Avatar
Thanked: 14,725 Times
Nice observation. Actually, its an age old trick, at least I can confirm that my old Zen has this 'structural patch' on the inside of the rear hatch. This patch is mainly on the 'curved' area on the rear hatch. A picture that I had taken while installation of rear wipers where you can see that patch inside:
Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal-inner-hatch.jpg
saket77 is offline   (9) Thanks
Old 18th January 2019, 10:52   #4
ashis89's Avatar
Thanked: 12,148 Times
Thanks for sharing. I have a few questions arising in my mind.
Will weight be the factor to decide if the body shell is strong enough?
Are the patches applied across the body? If not, we can try our thumb throughout the car to look for loopholes.
How effective are these patches and how much load can they take?
Are they glued onto the body? This can a potential upgrade items for existing Maruti owners like me who is afraid to lean on his car.
ashis89 is offline   (2) Thanks
Old 18th January 2019, 11:21   #5
Leoshashi's Avatar
I remember seeing that on your Zen. My curiosity increased when I saw it on Sumit's Ritz too.
No. Unless a car is crash tested in a lab, NOTHING ELSE can be a parameter for deciding structural integrity. With clever chassis design, you can eliminate the need of additional reinforcements. Most common example I'll give: Roof ribs and creases. Either put crossmembers and have a smooth looking roof on the outside, or eliminate the crossmembers and give ribbed pattern. If will give strength to the roof panel.
Want to experiment? Take two papers, fold one like this:
Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal-11362945354_af0d07aa55_b.jpg
And the other sheet should be flat. Apply force in the direction shown. Which one will be easier to crumple?
No, mostly at the central point of any stretched panel. But compared to a panel without any such patches, it will still be resilient to flexing if you press elsewhere.
Very effective, again see the video and decide for yourself. Will resist flexing equivalent to a panel which is made of thicker gauge steel. But mind you, only flexing.
Probably, but these things aren't available for end customers as of now. But I am sure it will be launched in future.
For the time being, you can stick damping sheets of same dimensions. Will give the same results, except the glue part which won't be so strong as the OEM ones. Damping sheets are in use in audio industry since ages to control the vibration of panels(again a flex).
I have done that on my car and the panels are noticeably resistant to flexing:
Link (The love of my life - A 2000 Maruti 800 DX 5-Speed. EDIT: Gets export model features on Pg 27)
Look at this video by 3M where they demonstrate the effect using a tiny sheet.
You don't need to cover the whole area, just a tiny sheet is enough to disrupt the free travel of the mechanical waves.
Shashi
PS: Another way of providing strength to panels is by providing creases. Try this, the panel won't flex where any crease is there. It will flex only where there is large area of smooth metal.
Leoshashi is offline   (16) Thanks
Old 18th January 2019, 11:37   #6
the_skyliner's Avatar
Thanked: 1,534 Times
Very useful and informative thread, thanks for sharing.
FEA can also determine the structural integrity. However, for the purpose of validation and legality, a test is required.
the_skyliner is offline   (1) Thanks
Old 18th January 2019, 11:53   #7
ashis89's Avatar
I understand that proper crash tests can give an insight into how safe a car is when involved in an accident. However my question was slightly different. Crash safety aside, I am also interested to know how a car can handle minor shunts - say a bump by a biker or cyclist or even a dash by a arrogant buffalo on the road.
Will the patch help in such cases? I am assuming it will help.
Another area where these patches won't help is minor and yet sharp dents such as from a stone, a cricket ball or a hit with a stick. These create small dings or imperfections on the body panel but are difficult to fix. A stronger panel will be more resilient in such scenarios. I know it sounds weird but these are some of the damages they we may face in our day to day lives.
I also understand the advantages of the ribbed roof and creases. Out of curiosity, won't it better if there are ribs in the inner side of the body panels and smooth on the outside. It might add to the weight but shouldn't it improve strength as well?
ashis89 is offline   (1) Thanks
Old 18th January 2019, 12:20   #8
The location of ribs (inner or outer side) will change the strength characteristics of the roof. Outer ribs will provide more rigidity against forces acting in case of toppling.
Having creases as well as smooth surface is contradictory and won't be feasible/logical. Better to put inner ribs instead of creases to achieve smooth outer surface (more weight plus cost).
Old 18th January 2019, 12:31   #9
R2D2's Avatar
Thanked: 5,849 Times
This is a great thread!
I am also interested to know how a car can handle minor shunts - say a bump by a biker or cyclist or even a dash by a arrogant buffalo on the road. Will the patch help in such cases? I am assuming it will help.
Actually IIRC patches are to prevent flexing and provide a level of structural integrity to the panel itself. It cannot prevent damage from external impacts. A buffalo swinging its heavy head and the animal's horn contacting the metal will probably put a nice noticeable ding patch or no patch. Ditto for a bike rider's crash guard having an unintended meeting with your car's sheet metal. It all comes down to the force applied to that spot. A patch may absorb some of that force and minimise inward deflection but it cannot prevent the ding.
R2D2 is offline   (4) Thanks
Old 18th January 2019, 12:41   #10
True that.
In fact, in some cases these patches will do more harm than good. For example, in case of rubber ball dent on car, these patches will make it hard to repair due to reduced flexibility. Without the patch, one can simply repair the dent with opposite force at right place (some mechanics are expert in knowing the right spot to hit).
the_skyliner is offline   (4) Thanks
Old 18th January 2019, 12:42   #11
Thanked: 2,559 Times
If applied only in patches here and there, it would not enhance structural integrity. At best, it will reduce sheet metal flex, when pressed. Only if the patch is end to end, would it affect the structural rigidity/integrity. Like a heavy rod piece, if welded to the middle of the door, it would only increase the weight of door panel, while end to end welding of a long rod (like a beam), will increase the structural integrity.
Nav-i-gator is offline   (1) Thanks
Old 18th January 2019, 13:41   #12
Blow Horn Ok's Avatar
Thanked: 993 Times
Curious to know the material of the reinforcement. Is it hard rubber? Or bitumin sheet kind of thing?
Guess the oem ones are more harder material than that of the usual damping material.
Blow Horn Ok is offline
Old 18th January 2019, 14:00   #13
After I got my Civic's doors professionally damped, they became noticeably heavier and felt as sturdy as the ones on my C220. They wouldn't flex as easily either.
GTO is offline   (6) Thanks
Old 18th January 2019, 19:36   #14
Thanked: 9,250 Times
Shashi, is this piece the same as the one usually found stuck to the car floor below carpet? Any information regarding the base material these are made of?
I was thinking whether there is an advantage of sticking this liberally on the outer skin of the doors and whether to purchase the OE ones sold my MGP or go for dynamat or similar aluminium backed sheet.
Sankar is offline   (1) Thanks
Old 18th January 2019, 19:48   #15
Leoshashi's Avatar
What Maruti uses is some kind of reinforced fabric type of stuff, sorry I am not aware of the material and I am trying to find out more about the vendors, details etc. For the time being, I can send you closeups of the material:
Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal-20181021_115138.jpg
Manufacturers using "structural patches" to reduce the flexing of thinner sheet metal-20181021_115146.jpg
These things are super hard to pry out, and will probably need even heating, such was their bond strength.
On a lighter note, Our dear friend Sumit is clueless what all mischief I keep doing with his cars.
The patches shown in Video by Henkel is more like the stuff which Tufclad/Dynamat uses.
The ones stuck below the carpet is known as Melt sheet. It won't be very effective on vertical surfaces unless its properly heated(which may damage the paint) and applied as its done at factory level. Add to that, its very heavy.
My experience with SGP Melt sheets: https://www.team-bhp.com/forum/long-...ml#post3989444 (The love of my life - A 2000 Maruti 800 DX 5-Speed. EDIT: Gets export model features on Pg 27)
Don't Miss Behram Dhabar Sir's comment on that page.
Dynamat or Tufclad stick better if applied nicely. I won't recommend Melt sheets for door outer skins.
Shashi
Leoshashi is offline   (5) Thanks
