Re: Dog tracking AKA crabbing - When cars are sideways while going straight Thanks for sharing!
Rear wheel drive cars with fixed rear axles and trailing arms set up are prone to this as well, due to simple wear and tear. It should not get as bad as in some of the video's. Not anywhere near it, but it is usually very noticeable and visible by stepping on the accelerator and or the brakes.
As the rubber mounts in the trailing arms wear, they begin to get some play. Effectively the whole of the rear axle can start to "wobble" a bit.
It is an effect that many owners on older cars might have come across. It feels as if the back of the car gets pushed left or right and you compensate by steering the other way. For some reason I have always noticed the effect to be more pronounced during accelerating then with braking. (Probably to do with the fact that most braking force comes from the front wheels).
You step on the accelerator and the rear of the car moves a bit sideways. On a straight end, normally not a huge deal. But in a bend, where you like to accelerate and make use of rear wheel drive characteristics, this could spoil your day. It really upsets the handling of the car.
It is a known area of attention of for instance earlier Alfa Romeo's. The easy fix is to replace the rubber bushings in the trailing arms and the diablo rubber that holds the differential in place under the chassis.
Original Alfa Rubbers would not last more then 50-75.000 kilometers. These days with modern rubbers they could last a lot longer. But ultimately they will wear down. And needs replacing.
Jeroen |
