Old 10th September 2012, 22:23   #46
bejoy's Avatar
Thanked: 1,558 Times
Re: New Brio Headlights Fogging
Originally Posted by Ragin_Ice View Post
Is it normal? And what should be the next steps?
It is not normal. This is a problem with the sealing, causing the moisture to enter the headlights. In the long run this causes the fading of the reflectors and makes the lights ineffective. Ask the service center to replace the lights under warranty. Is there condensation in both the headlights?
bejoy is offline
Old 10th September 2012, 22:41   #47
negativeH's Avatar
Thanked: 73 Times
I think I read 'bout this recently on another Brio in a different forum, will try and search for it, or was it you only?
Check with other Brio-ans, could be a quality issue with a certain batch.
negativeH is offline
Old 10th September 2012, 22:45   #48
sumeshmani's Avatar
Thanked: 111 Times
This is not normal. My friend faced the same problem with his new Figo. Even the replacement head lamps had the same problem.
Then some expert from Ford came to check the issue and gave my friend some physics equation as the excuse.
When my friends got upset and pointed out that the equation does not seem to hold good with all the cars out there, the expert just lost his words.
The headlight was replaced again and there after he has not had that issue.
sumeshmani is offline   (2) Thanks
Old 10th September 2012, 23:39   #49
Reality's Avatar
Thanked: 34 Times
Even i feel its not normal. But hyundai managed to send me a mail which states why it happens.
Reality is offline
Old 11th September 2012, 16:56   #50
Thanked: 52 Times
Re: Moisture / Water / Fogging inside the Headlamp
This is what I found when I googled a bit: http://www.myzroadster.com/Files/tsb.../NTB03-074.pdf
It says that some amount of moisture is alright (see figure 1 and 2). My case is No.1 exactly the way shown in the diagram. There is no collection of water and the fog disappears in 2 mins of operation.
In the meanwhile I logged a complaint at Honda and they have asked me to get my car to the service center.
Ragin_Ice is offline
Old 25th October 2012, 19:44   #51
BinFord's Avatar
Thanked: 35 Times
I too have this problem in my IKON after the headlight assembly replaced after an accidental repair. Now the replaced headlight will accumulate the moisture during rains and it drains off after 2-3 days.I can see a visible difference in the bumper joints between the right and left side and might be the cause of water goes in.
My question is will this cause the bulb to fuse at long run?
BinFord is offline
Old 27th July 2014, 21:16   #52
aghosht's Avatar
Thanked: 17 Times
Has anyone got a warranty replacement for water in a new headlamp. My car is a Grand i10 and has done about 2000 kms. Everything is untouched - no mods etc.
Please can anyone let me how to go about it (without going through the dealer - I'm sure that way will be the most painful!). See pics below -
Moisture / Water / Fogging inside the Headlamp-img_20140727_104738.jpg
Moisture / Water / Fogging inside the Headlamp-img_20140727_192854.jpg
aghosht is offline
Old 27th July 2014, 22:47   #53
Thanked: 21,218 Times
My WagonR had this issue. There was condensation in one headlamp. The other showed little signs of condensation. During service I reported this issue and they had removed the assembly and dried it. However after a couple of days the issue cropped up again. I called up the service center and they told me to get the car. Both side headlamp assy was replaced within an hour.
I didnt understand how you can get it done without going to dealer. They are the ones responsible for any warranty claims so I am not sure if there is any other way.
Old 27th July 2014, 23:00   #54
ajaypjayaraj's Avatar
Thanked: 1,166 Times
The water has entered the head lamp casing for it to evaporate and condense on the inside of the glass.
The water ingress could be through the cap provided behind the head lamp for replacing the bulbs. It could be either not put properly in place to be water tight or the rubber gasket for making the cap watertight may not be in place or the cap itself could be missing. You can check the cap behind the headlamp and find if these are the reasons, which can be resolved without a change of headlamp or any major work.
If that is not the case then the casing has a leak somewhere which will be a warranty issue in which case the dealer will sort it out for you under warranty.
ajaypjayaraj is offline   (1) Thanks
Old 28th July 2014, 07:03   #55
itwasntme's Avatar
Thanked: 14,150 Times
Simply take it to any dealer for thorough inspection. They will examine and ask the necessary questions like accident damage, unauthorised modification etc, but will change it under warranty.
Clear case of a manufacturing defect.
itwasntme is online now   (1) Thanks
Old 28th July 2014, 07:09   #56
naveen.raju's Avatar
Thanked: 9,469 Times
As Ajay pointed out, it should be a faulty rubber seal. See whether it's missing or got any hole or breaks. If that's the case, get it replaced. Going to the dealer is the best practice as the car is still on warranty. If you get the work done outside and still the problem exists, then the dealer can/will deny warranty saying that your car was fiddled by an unauthorized workshop (this can happen). So I would recommend you to visit the dealer. At first they might replace the rubber seal (if it's due to this, it might take 1 or 2 days for the condensation to disappear). If the problem still exists, ask them to replace the headlight assembly.
naveen.raju is offline   (1) Thanks
Old 28th July 2014, 07:45   #57
Thanked: 21,450 Times
As others have suggested, it is good if you go through the dealer as the job will be recorded in their database and the replacement will be hassle free.
This is totally a manufacturing defect so you shouldn't face any issue with the dealer.
Anurag.
Old 26th May 2022, 17:43   #58
josethundiyil99's Avatar
Thanked: 109 Times
How do I remove the condensation inside my Baleno's headlights? Few YT videos suggested cleaning the vent, but I haven't seen any vents behind the headlights. Please help
josethundiyil99 is offline   (1) Thanks
Old 18th December 2022, 15:59   #59
Thanked: 55 Times
Did you manage to find a solution for the condensation issue? I am facing the same issue in my Baleno.
y448 is offline
Old 13th January 2023, 11:12   #60
johy's Avatar
Thanked: 634 Times
I am facing condensation issue in my year old Hyundai i20 NLine.
The service center and territorial sales manager, both say that the issue is natural due to atmospheric conditions, etc and won't hamper anything. Would like fellow team-bhpians inputs on this one. The TSM further went on to say that when they changed the dust caps, it is because there is some silica in the dust caps which absorb any extra moisture.
They changed the dustcaps at the 1-year service, but I don't know if it did anything, as I still see condensation now and then, maybe the condensation became a bit less, but I cannot be certain.
The condensation usually appears when I go out to drive in the evenings and park the car under the shade.
Moisture / Water / Fogging inside the Headlamp-nline_headlight-fogging_no-plates.jpg
johy is offline
